models of cars
spliffy
models of cars
can any of you boffins out there tell me which other models of cars share the same engine as a 2.0l t xantia 1998 and would take the ecu cheers any help would help me to find a new car as i cant find a replacement xantia
Spliffy
have owned : renault 21,mk1 megane 1.6 8v
currently own renault megane grand scenic ( 1.9 dci privelige )
currently own renault megane coupe 1.6 16v
KP
- x 27
KP
- x 27
MikeT
- x 232
spliffy
im in need of a road legal car asap and im wanting to put my ecu and lpg conversion onto it as my xantia has been written off so im wanting a citroen or peugeot with a 2.0l t xu engine i was just wanting to know what other models have that engine in cheers
Spliffy
KP
- x 27
MikeT
- x 232
spider
- x 77
Posted more info in the Peugeot section as saw a topic in there asking more or less the same.
In brief (check your topic in the Pug section though)
406 SRi (not that common, but ALL these have the 2.0 8v turbo unit), they did not make this model for long afaik. I used to have one to use (a P plate one, when it was new)
, was great fun.
Early 406 2.0 exec's have the 8v turbo unit. Early = as in the first year or so I think of production. Later ones have the usual 16v n/a unit
Some 605's although I am not sure if this model was sold in the UK.
Andy.
- x 8411
As well as the Pugs you mention Andy, the 2.0 CT also found a home in the XM, normally hooked up to an autobox. Not forgetting the 2.0CT Xantia Exclusive Estate of course. Activas without rams
All I can say is it's a good job Andmcit did not see your comment...
Mike, if you were not such a valuable member of this forum, your account would be toast buy now for even thinking of such a thingKP wrote: jim will be here soon banning your account lol!
Deanxm
- x 87
This is where the trouble will start, auto's have a specific map and so do manuals, i also know there were several ecu types for the TCT, the main ones were adapted for odb then odb1 and i think 2 aswell and in between there were some changes. care must be taken.
D
Im loving the vast array of smilies by the way, should be forum rules that these are used at least daily
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
