I took out my pinion valve and had it kitted. $50 labour, and somewhat more for the seal kit. Replaced the return hose and it was all dry again...
Leaking steering rack
addo
- Sara Watson's Stalker
- x 95
- x 1473
Something that still maybe needs clarifying (so you ask for the correct adjustments) is that there are 3 different things any one or combination of which might now be wrong on your car.
1. The straight ahead tracking (that the front wheels are pointing more or less in the same direction) if wrong, this causes tyre wear.
2. The rack centering (when the front wheels are pointing straight ahead, the rack is exactly at its mid point). If wrong this can strain the airbag connector.
3. The steering wheel is centered (when the rack is at its mid point, the pokes of the steering wheel are correctly aligned).
On one of my cars, after having the alignment done (due to abnormal tyre wear), they got 1 right, 2 wrong and then moved the steering wheel so that 3 looked right.
XantiaDaveEire
- x 4
Second hand rackaddo wrote:That's thievery!I hope it was a brand new rack.
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k
Gammy leg
XantiaDaveEire
- x 4
addo
- x 95
- x 8427
Veggie sausages can be good Adam. Our Quorn ones aren't bad...addo wrote:As a committed vegetarian, you'll not hear that from me.![]()
I have to confess I'm an ex-vegetarian. Fried bacon was my downfall and I succumed to the temptation
Truth is I don't eat much meat, just a little chicken, fish and a bit of bacon. I don't like red meat and rarely eat it.
