rear brakes locking up on my 1998 megane 1.6 sport
spliffy
my car seemed fine when i last used it then when i went to use it again the osr wheel was seized on i had to whack it off using a big chisel and hammer when it eventually came off the brake lining had come off im not sure whether the lining caused it to seize or by it has come off because it was seized is this a common problem if so what is the cause eg adusters cables cheers
Spliffy
have owned : renault 21,mk1 megane 1.6 8v
currently own renault megane grand scenic ( 1.9 dci privelige )
currently own renault megane coupe 1.6 16v
spider
- x 77
At a guess, it probably pulled the lining off the shoe backing when you forced the drum off (I know you did not have a lot of choice)
Typically I'd guess it had seized on (handbrake posssibly)
New shoes, strip the adjusters / springs etc all down, ensure everything is free to move, rebuild.
Andy.
evilally
- x 3
spliffy
