brake pedal sinking c5 hdi
sportingfiat
Unread post by sportingfiat »
after changing my faulty caliper and bleeding the system twice, if you start the engine and press the press they go hard but if you keep your foot on the pedal it slowly over 10-15 secs sinks to near the floor
is there something else to bleed as well as the brakes or any ideas whats up?
does sound like a pump running somewhere near the master cylinder too, is this the abs pump?
cheers
h2ocooler
Unread post by h2ocooler »
My guess is the master cylinder seals are letting by, if the pedal goes hard then sinks its not air in the system, it would still be soft.
ABS pump would not kick in unless you were moving.
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
x 1490
Some modern cars just seem to do this - you may simply not have noticed before as you have never tried it whilst thinking about it. I'm pretty sure the Vectra (yeah, I know!) does it for instance. Any other C5 drivers confirm the status of their sinking??
dnsey
x 19
Unread post by dnsey »
Yep, my C5 does the same. The brakes work well, have been bled, and I can find no (external) leaks.
I think it's just one of those things.
I can't imagine ever having to brake hard and long enough for the pedal to run out of travel!
Citroenmad
x 110
Re: brake pedal sinking c5 hdi
Unread post by Citroenmad »
sportingfiat wrote: does sound like a pump running somewhere near the master cylinder too, is this the abs pump?
cheers
Is the pump a sounds a of small running motor over towards the n/s strut top? I have that one mine, though i only hear it when ive turned the car off and got out. Its quiet but easily heard in the garage. Seems to stay running for a few minutes after stopping the car. Anyone know what that is?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 5672
Could be the motors closing the ventilation flaps.
