Thanks for that info Mike. Therein lies the problem, as the haynes manual only states that you need a lexia to set it up, so I assumed the lexia did the clever stuff and showed you when the TPS was correctly set up or something... or that there was a reset carried out via the lexia with throttle not touched, to let the ECU know that's the resting position of the TPS and to take that as the minimum and everything upwards is movement. Calibrate it, basically.MikeT wrote: which I suspect you can set the TPS to if you know the spec.
Rough Idle on Xantia 1.9TD.
JamesQB
- x 5
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
MikeT
- x 232
Hi James,
As you say, the fast idle is default. It requires mechanical intervention to be de-activated and is irrelevant when the engine speed exceeds it (obviously).
The TPS, (or more correctly the load lever position sensor) has no bearing on the idle directly. If you want to check it yourself, you should see a reading of ~0.9V at rest and 4.5V at full swing.
Xaccers
- x 188
I had the same thing with Cassy until Saturday when I finally got time to look at it.JamesQB wrote:Will a Lexia 3 give information on whether or not that lift sensor is working? And does it allow for setting the TPS position correctly?
I ask as my parents' 98 Xantia 1.9TD has similar trouble and is stuck on fast idle despite new solenoid. For some reason ECU isn't activating solenoid to cut the fast idle. Idles at just over 1000rpm and has that deep rattling noise someone else mentioned.
Moved the airbox and it's first large pipe out the way so I could get to the electrovalves at the back of the engine bay.
Placed a finger on each and reved the engine, feeling for which one went click.
Made sure that was connected to the fast idle cable, and connected the vaccum pump directly to the top of it as I don't use the EGR.
Revs dropped to 800-850 and she sound much smoother.
DIY sphere tool
DIY sphere tool
KennyW
- x 165
Hi All,
I've viewing the postings with interest.
To use my multimeter what terminal numbers are we testing and what are we testing for?
1. Engine coolant temp sensor green connector at rear of thermostat housing.
Is it volts,amps or ohms?
2.Idling electrovalve
3.EGR electrovalve
4.Injector needle lift sensor
Is it volts,amps or ohms and working ficures.
Kenny
3.EGR electrovalve
Kenny
C3 1.4 petrol (SWMBO)
MikeT
- x 232
Hi Kenny,
1. Set to 20K ohms scale, measuring the two pins of the sensor. Something like 6K stone cold, falling as temp rises.
2. Supplied with 12v +ve and -ve, is either on (can be heard/felt to click as Xac advises) or off. Expect it to be off when engine is cold and come on once up to temperature (though they've never worked in both my Xantia's and the high idle when warm is usually an accurate sign of failure).
3. Don't care. It's the work of the devil and should be disconnected IMHO. But same principle as #2, it's eitther activated or not dependant on engine load I think.
4. Not entirely sure but I suspect it outputs millivolts (0-0.9), varying with injection lift.
KennyW
- x 165
Cheers Mike,
Will check this week and get back to the forum with figures.
Kenny
Kenny
KennyW
- x 165
Hi All,
Slight delay in checking but here I go.
Needle lift sensor I got 137 ohms which is a bit higher than 90 -100 ohms but this was a cold engine. I presume engine has to be at running temp.
Again, I checked the resistance across pins 1 & 2 I hope that was correct but more importantly does the engine have to be running
Kenny.
Kenny.
MikeT
- x 232
KennyW
- x 165
Hi Mike,
I think my problem is No 3 Injector where the needle lift mechanism is located and probably faulty.
I am thinking of changing it for one from the scrappie, tempted to remove part of the wiring loom but it looks to be more trouble than it is worth.
Kenny
Kenny
- x 8410
MikeT
- x 232
Thanks for confirming that Jim.
Kenny, you know you can test individual injectors by releasing the fuel pressure and seeing if the problem disappears. What makes you suspect it's #3? It works on the same principle as the others, the only difference is the lift-sensor, an odd-on device that merely measures movement, it does no actuating.
- x 8410
KennyW
- x 165
Hi Jim,
I think the nearest member is David Hallworth in Glasgow with a lexia, he has kindly suggested to contact him if it requires testing.
Kenny
Kenny
