c5 radio beep
Kieran
c5 radio beep
Unread post by Kieran »
Hi, I have a C5 2.0 tdi 110bhp (02), whenever I switch the radio on it works, however there is a loud beep every second, and also the CD player does not work.
Also does anyone know if it is normal for it to be so sluggish? I have also had an old golf tdi estate with 20 less bhp, and it is by far quicker accelerating.
Any ideas would be appreciated.
Kieran
Citroenmad
x 110
Unread post by Citroenmad »
2.0HDi 110s arnt very sluggish i wouldnt say, our two are quite lively performers.
Maybe get it on a lexi computer adn see if there are any fault codes in, i had to replace a MAF sensor a few weeks back which was causing it to be much slower than normal.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Kieran
Hi yeah I did mean HDI. This one is very sluggish! We have only just purchased it. I will arrange to get it plugged into a lexi computer. Do most garages have this or would it have to be a dealership?
I will post back when I have found the solution.
Cheers
Dommo
x 20
Unread post by Dommo »
The computer system is called a Lexia, just so you don't sound like a weirdo asking for a lexi!
x 5613
Kieran wrote:Hi yeah I did mean HDI. This one is very sluggish! We have only just purchased it. I will arrange to get it plugged into a lexi computer. Do most garages have this or would it have to be a dealership?
Cheers
Take a look on this map and see if there is a member with a Lexia near you, that you could arrange to have your codes read/cleared by.
Kieran
Hehe, cheers guys.
Lexia computer systems don't seem to exist in North Wales!
MikeT
x 232
Re: c5 radio beep
Unread post by MikeT »
Kieran wrote:Hi, I have a C5 2.0 tdi 110bhp (02), whenever I switch the radio on it works, however there is a loud beep every second, and also the CD player does not work.
Hi Kieran, I got that (on Xantia) when it doesn't have Security Code entered after disconnecting the battery.
I read elsewhere, it's a clever "function" to test the radio actually works even if you don't have the code - hence the annoying bleep and why the CD won't work. Ergo, enter the code and all should be well.
Kieran
Ah cheers for that. I was wondering if it had something to do with the sluggishness of the car. But i'll try and get that sorted. Thanks for your help.
x 5613
Re: c5 radio beep
May be something different, C5 radios are hard-coded to the VIN in the BSI and shouldn't - can't have a code entered. After a battery replacement or disconnection the radio should work but will need all the presets reasigning.
Kieran
Thanks for the updates, hopefully somewhere in North Wales someone will have the Lexia system to get it sorted, cheers.
Clogzz
x 40
Unread post by Clogzz »
A loud beep, apparently from under the dash, fixed by disconnecting the battery:
http://www.frenchcarforum.co.uk/forum/v ... p?p=213570
Citroenmad
x 110
Dommo wrote:The computer system is called a Lexia, just so you don't sound like a weirdo asking for a lexi!
Sorry about that, i really should re-read things once i have typed them!
If it really isnt performing right, a code should have been stored, a Lexia will be able to tell you what is wrong, if anything.
03 Seat Arosa 1.0S
Kieran
Clogzz wrote:A loud beep, apparently from under the dash, fixed by disconnecting the battery:
The difference being that it only beeps, when the radio is on, no radio no beep.
It's going to a garage on Tuesday so hopefully it will be sorted then.
Cheers
coastline taxis
Unread post by coastline taxis »
When the radio bleeps when its switched on it means that its not coded into your car (probally been swapped over) dealer only very easy repair it just needs vin code putting in.
Sluggish take the bottom hose of your intercooler and let it stand for a good few hours and watch all the oil come out of intercooler and hose replace pipe and give car a drive
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I don't know whether this applies to a C5 radio but if the Traffic announcment (TA) button is pressed and the radio is tuned to a non RDS/TA station then they often beep continuously.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
