Lexia2 limitations
Sl4yer
Unread post by Sl4yer »
There's some Pug info here Mike, which may be similar. Of course, who's to say it's correct? :roll:
I checked the pins in my Chexia 3 the other night. All are connected except pin 4...
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
MikeT
x 232
Unread post by MikeT »
Hi James,
Thanks for the info. The Pug diagram adds weight to the suspicion that there could be more pins connected than I currently have. To confirm this, I've been searching for the wiring diagram which shows the 16-pin DLC but it's eluding me. Obviously it won't show the pinouts for the other end of my cable but it'll be a good starting point to nailing down my Lexia failures.
MikeT
x 232
With kind thanks to citrojim in providing me with the missing pinouts, I'm very pleased to announce I can now get dialogue with all ECU's in my Xantia. :clap: \:D/
If you're reading this Toby, I'd appreciate the loan of your Coupe again sometime to check my "Diaxia" can now fully diagnose Pugs as well.
Toby_HDi
x 3
Unread post by Toby_HDi »
Mike, great news.
I did post on t'other site but got no interest whatsoever.
Can pop over Sunday or Monday, whichever is easier. I also have your replacement tool.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
x 94
Unread post by citronut »
Mike i have sent you a PM regarding the pin outs you required, but see you are sortted now, but if you would like my version also just to confuse a bit more, send me your email address and i will forward it to you, as i have scanned it into my comp the nooooo
regards malcolm
Sl4yer
Mike,
Any chance you can share the correct pinouts? My Chexia will do everything but the aircon. I've got another car in mind to test it on, in case my Activa is faulty, but I've got to psyche myself up to approaching a total stranger who probably won't know what I'm on about!
2008 Mazda RX-8 231
MikeT
x 232
:oops: I should of course extend my thanks to citronut and superloopy1 for their kind assistance, time and patience as I know too well what a PITA it is to have to buzz out looms single-handedly. Even moreso if you got a digit missing :!:
Thanks also to Toby for letting me "experiment" on his pride and joy. Brave man! Oh, and don't worry about replacing the broken tool Toby, I know you wouldn't make me pay if I broke your car :P :wink: Toby, please call whenever's convenient for you. I'll be around all weekend.
Malcolm, PM replied and complied.
MikeT
x 232
Sl4yer wrote:Mike,
Unfortunately, the Lexia3 and Lexia2 terminate in different connectors and I was given the pinouts from OBDII 16 pin to D-Sub 37-pin whereas I believe you have OBDII 16-pin to round 30-pin?
Sl4yer
MikeT wrote:Unfortunately, the Lexia3 and Lexia2 terminate in different connectors and I was given the pinouts from OBDII 16 pin to D-Sub 37-pin whereas I believe you have OBDII 16-pin to round 30-pin?
That's correct Mike. Perhaps you could tell me (although I think I know the answer!) whether pin 4 on the OBD2 plug goes anywhere on the Lexia 2. I'm suspecting it does!
Thanks,
2008 Mazda RX-8 231
x 1056
Unread post by wheeler »
Sl4yer wrote:Mike,
Have you tried to get dialogue with the enging running ?
Lexia tells you on some models that the engine needs to be running to get dialogue with AC.
x 94
James wrote
"whether pin 4 on the OBD2 plug goes anywhere on the Lexia 2. I'm suspecting it does!"
on my 37 to 16/OBD lead for my DIS/LEXIA 2, pin 4 on th 16 pin OBD plug goes to pin's 3 and 21 on the 37 pin D plug,
regards malcolm
x 1441
Unread post by xantia_v6 »
Sl4yer wrote: Perhaps you could tell me (although I think I know the answer!) whether pin 4 on the OBD2 plug goes anywhere on the Lexia 2. I'm suspecting it does!
On my chinese lexia 3, (which also refuses to talk to several ECUs), the conne ctions on that cable (round connector LH column, 20 pin connector on PCB center column, 16 pin connector RH column):
Code: Select all
1  14 1
2  9  12
3  2  5
4  17 5
5  19 9
6  1  16
7  7  13
8  10 3
10 16 -
11 6  7
12 11 10
13 15 -
14 5  14
15 14 -
16 13 -
21 4  8
24 12 2
25 18? 11
29 3  15
30 8  6
I think that pin 4 is deliberately not connected as it iand pin 5 are ground pins on the car, and a ground-loop could damage the lexia if both were connected.
The internal pin number with a question mark above is actually O/C in my cable, but I am fairly sure it connects to (at least) the A/C ECU.
Sl4yer
xantia_v6 wrote: I think that pin 4 is deliberately not connected as it iand pin 5 are ground pins on the car, and a ground-loop could damage the lexia if both were connected.
Thanks for that Mike, and everyone else for the info. (I've got the same OBD2 to 30-pin connections as you). Mine will connect to everything except the aircon ECU (that is, engine, suspension, CPH, ABS all work fine). I think another car to try must be my next option.
Wheeler, I always Lexia with the engine running (usually exercising the suspension up and down), although I've tried it with the engine off too just in case!
Anyhow, I'm dragging this thread off-topic - apologies MikeT!
2008 Mazda RX-8 231
