espace DCI 2.2 Cutting out
This is the Forum for all your Renault Technical Questions, Problems or Advice.
little.tubs
Unread post by little.tubs »
Hi,
Could somebody please give me some advice on my Fathers Espace, 3 weeks ago when driving under load the car cuts out and all electrics go, if you turn the ignition back then back to position 2 it is fine, but drive under load again it does the same again.
My father has taken it to 2 local garages, they both said it was the EGR valve and stripped it down and cleaned it, but they were both wrong as it was still doing it, my father took it to a renault garage and they think it is either the injectors or the main fuel pump, could someone please advise if they have experienced anything like this as thet are quoting £700 for the pump with vat and labour.
PLEASE HELP
Regards
Rich :?: :?: :?:
bartontink
Unread post by bartontink »
hi have you solved this problem as ive got a simalar fault
