Rear wheel grinding on the brake caliper ?????
JonWill
Hi, I'm the owner of a Citroen C5 Mk1 (2001) and have had to take it off the road due to the inside of the rear wheel rim grinding on the brake caliper, as any one come across this before and how can I fix it.
- x 1431
Hi Jon, welcome to the forum
'Tis a common problem on the C5, but to be bad enough for the caliper to be rubbing on the wheel is pretty far gone
The problem is corrosion build up between the (aluminium) caliper and (steel) radius arm. The cure is to remove the caliper, clean the rust off the back and refit it. Trouble is, the bolts are a royal pain to get out without breaking them (go steady, use Plus Gas on the back, and heat if possible) and to make matters worse, on the C5, Citroen saw fit to drown the bolts in thread lock, so heat all along the bolt is required. The C5 calipers seem to be made of a particularly soft alu as well, and corrode like nobody's business, so new calipers may be in order....
JonWill
Citroenmad
- x 110
Yes very common problem, first sign is rear brake pads wearing like a wedge.
I had mine to bits a couple of weeks ago to grease behind them, though it had new calipers about 6 months ago i thought id see whet they were like now. All was good and should be for a good few years hopefully.
Quite a common thing to have to replace the callipers when this happens, and yours does sound quite bad. You will also be needing new pads as they will have worn very odly and wont fit to the disc once the caliper is back in its normal place.
Callipers are about £70 each from aep-parts online.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Pleiades
Yes t'is a very common sight on the C5 and also on the Xantia.
As part of a service now, we allways remove the calipers, clean the backs and grease em up.
As Richard says, Citroen did drown these in loctite before fitting them, so removal does require heat, patience and good quality tools, (cheap sockets will not fit right and round off the heads)
To the extreme, I have had these in when the corrosion had built up so much, it had snapped a bolt in the caliper.
Anyone that has a C5 or Xantia that has not had this problem, I would suggest fix it noe before the problem exists.
You can remove the calipers without losing fluid and without the need for bleeding, my way is this...
Remove the bolt / pin that holds the pads in, (8mm)
Remove the pads and push the pistons home.
Put the bolt back in to hold the caliper halfs together.
Remove the 2 x caliper bolts.
Do the big clean up and put all back together in reverse order.
Regards
Martin.
Regards
Martin.
Citroenmad
- x 110
Thats exactly what i just did last weekend with mine, though i need to do the other 2 C5s too. Easy enough as long as you can get the bolts out.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Xantidote
- x 5
