keys, do they really have to be this big???!!
- x 1454
It seems that some people don't realise that the transponder chip for the immobiliser is in the plastic mouled end of the key shaft itself, and has no connection to the RF PCB that works the locking system.
Your car would originally have had a service key which has a slim plastic head and no plipper body, at a cost, you could get a replacement from Citroen, or you could just pop the rivet and find a way to get a bit of leverage on the key shaft from your plipper.
jgra1
- (Donor 2021)
- x 37
http://1.bp.blogspot.com/_2fj8MH_LeQ0/S ... antkey.jpg
the service key.. the green bit is the chip.. looks quite well secured
wright
xantia sx auto
oh cool thanks, any idea how to pop this rivet??? I doubt ciroen would help as i don't have the card thing with key numbers on, but could they make a service key from my key or would they need key codes and does anybody know what it might cost me? (probably more than i paid for the car!!!)xantia_v6 wrote:It seems that some people don't realise that the transponder chip for the immobiliser is in the plastic mouled end of the key shaft itself, and has no connection to the RF PCB that works the locking system.
xantia sx auto
I don't have the service key that is my problem!jgra1 wrote:http://1.bp.blogspot.com/_2fj8MH_LeQ0/S ... antkey.jpg
Citroenmad
- x 110
I would get a service key, it wont cost a fortune and you will have a good sized key, instead of a tiny plastic ended blade.
If you do decide to drill out the rivet, Citroen sell a kit for a couple of pound which is the rivet and spring.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
jgra1
- (Donor 2021)
- x 37
xantia sx auto
How can i get a service key if i don't have that card with key numbers on? i thought they needed the number to make it work in the car for immob???Citroenmad wrote:I would get a service key, it wont cost a fortune and you will have a good sized key, instead of a tiny plastic ended blade.
MJM
Citroen dealer can look up the key number on their database. They may or may not charge for doing this. If you have to obtain the key number, it's worth getting the radio code and the security code as well. You may also need the V5 document to "prove" that you own the car.
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
xantia sx auto
if they do charge what will the charge be? also don't have v5 as only got it yesterday and the bloke only had a very old type v5 so i got a green slip but a very very old one!!MJM wrote:Citroen dealer can look up the key number on their database. They may or may not charge for doing this. If you have to obtain the key number, it's worth getting the radio code and the security code as well. You may also need the V5 document to "prove" that you own the car.
do timpsons do them,!!!! lol
MJM
The "standard" charge used to be £15 for the 3 codes. I was quoted £15 for each number by one local dealer.
I went to the main dealer in Gloucester eventually (happened to be passing) and was given the 3 codes for nowt.
(I always think that being pleasant and polite is a help.
The radio code can be accessed by the dealer at any time but the other 2 can only be accessed when the main Citroen UK database is open (9 to 5 Mon to fri?) The dealer gave me the radio code but being Saturday couldn't do the other codes. I said that a phone call with the others would be ok, when he had them. It would save me calling in. I then offered to pay and was told to not worry about it.
You have proof of ownership with the slip, and presumably you'll drive to the dealer in it so ownership won't be a problem.
MJM
Citroenmad
- x 110
When i wanted a radio code for an Xm the dealer had to request it from Citroen UK. The dealer phoned me about an hour after i went in and told me the code. £15 they charged and insisted they needed the number off the back of the radio.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
xantia sx auto
- x 8378
Ahh well, that's a MK2 Xantia for you. The vastly superior MK1 did have a key operated boot lockxantia sx auto wrote:
just need to work out why my boot only opens arter about 5 unlocks now, shame there is no key hole on boot of estate!!!
This'll be down to a failing central locking motor. They're not of the best quality on a Xantia Estate. They can be replaced by a generic motor obtainable from Maplins. VertVega did a post about this a while back. giving full details.
The locking motor is easy to get to after removing the tailgate trim panel and membrane. Be aware that the membrane is critical to the rear of the car being watertight and it'll need careful resealing as discussed in this thread.
- x 8378
Here's the thread about tailgate locking problems and how to solve them
