noticed today a black skiney substance around 2 injectors on C5 1.6 hdi 2005. ticked over the engine and i thought that i could hear a leak around the injector
anyone got any ideas as to what problem I have
i
black shiney substance around injector on c5 1.6 hdi 2005
citrokid
Onlinemyglaren
- x 5624
citrokid
Onlinemyglaren
- x 5624
You should be OK running the car for a while but eventually you will burn a channel in the injector seat.
You could do this yourself and a bit of a search will reveal the methods to be employed. Be very careful with them, the tips are very delicate.
Once removed you need to clean the seat thoroughly without getting any debris into the cylinder. Then replace the fire shields and the copper sealing washers.
Have a read through this thread from the Honest John forum. Sometimes - most times, the injectors come out easily enough but when they don't...
The 2.2L HDi is perceived to be the worst engine for this.
If you damage the injectors they are ±£250 each and need to be calibrated into the engine so if you are unsure of your capabilities in this department I would pass it over to someone with the suitable skills and experience - not a dealer!
A local diesel specialist would be a reasonable choice but have them quote you for it in case the prices run away with you once the job is underway.
citrokid
citrokid
leak past injectors
Got car back from injector specialist, 2 injectors leaking, service kits applied to all injectors,
cost 1100 euro mad mad mad ..
also they tell me the diesel is bad quality (dirty) and has caused most of the problems and change filling station !!
h2ocooler
1100 to fit new seals, did you have the injectors serviced at the same time??
I did the injector seal and fire shields on my 2.2HDi and the parts only came to a few quid, for that price you could have had new injectors.
Rob
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
citrokid
