I have recently purchased a 1998 Citroen Xantia fitted with a 4035 RDS Audio System which has a problem as follows:
1. The radio will ONLY work if the on/off and the BND buttons are depressed simultaneously, it will NOT work using the on/off button alone
2. When working stations change ok and volume controls are fine but the radio emits a constant beeping sound
3. After running for only a few minutes the radio switches itself off.
Any advice on solving this problem would be appreciated.
Citroen Xantia Radio problem
red_dwarfers
- x 58
Sounds like you're in need of a radio code
Might be worth sifting through the documentation for a 4 digit code, sometimes the code can also be written on the radio unit itself if pulled out.
I would point you in the direction of 'Old Guy's Xantia Pages' as he has some radio code calculators on there. Unfortunately, being a Clarion its not possible to get the code from the serial number. If you're good at soldering you can get the code by reading a tiny surface mounted chip or alternatively by ringing the main dealer who should be able to get it providing its the original fit radio and not from another Xantia.
Kev
'19 C4 Cactus 130 Flair
spider
- x 77
I know there are a (few) Clarion you can get it from the serial (some 306 ones I used to be able to do in my head) , although I doubt very much this is the same 'type' as red_dwarfers has said...
Andy.
citroenxm
- Fallen Hero
- x 70
Xantia Clarion radios DO NOT decode from the Serial!
The Chip needs reading... If gordons is getting a radio Station, then the code has to have already been put in, because the radio simply does not work before its put in..
Id say its a duff radio, and replacment is neccery...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
spider
- x 77
I'd agree it can't be done via the serial.
But, a lot of them do have a testmode. In this they work for up to an hour, no code is needed and nothing is 'saved' (stations etc) afterwards...
Its typically activated by holding down a couple of buttons for a few seconds.
Andy.
KP
- x 27
Spud
