Back end feels weird on my xantia
miggy24
Unread post by miggy24 »
Hi guys well in the last few days if i steer the car left the o/s/r of the car flings in and when im on the motorway it gets bad the and is hard to to keep control of.Can anyone tell me what this could be.Thanks
HDI
x 7
Unread post by HDI »
Checked the tyre pressures ?
If not that then it could be a failed radius arm bearing ? Look at the car from the back about 20 ft away , if one or both of the wheels is leaning in at the top it's radius arm bearings.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Old-Guy
x 32
Unread post by Old-Guy »
Checked the sphere on both rear corners? Unlike a broken steel spring, with a flat sphere you don't get a 'droopy' corner, just little or no suspension movement. the only 'spring' you're left with is the tyre!
I 'killed' a n/s/r sphere by going over a raised cattle grid a bit fast - narrowly avoided taking to the open common on landing! This prompted a swift change of all the spheres - after 12 years, long overdue.
