Hello!
We've got a Series 1 V6 24v Xantia which seems to be using an immense amount of petrol.
When you are parking or going round a corner it smells really strongly of raw petrol.
I've had it up on the ramp in the workshop with it running and I can't find anything anywhere that appears to be dripping or anything.
Has anybody experienced this sort of thing before? I was wondering about replacing the fuel lines on it but thought I'd ask here.
David.
Xantia V6 Smells of Petrol
DHallworth
- x 161
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
addo
- Sara Watson's Stalker
- x 95
Look at the front edge of the OSR wheelarch where the fuel pipe goes into the tank.
Also pull up the rear seat and look at the tank pump/sender closure for signs of leakage.
Check your motor mounts and the junctures between hard line and rubber flex down low on the firewall - excessive engine movement may strain them.
Examine the infeed and return lines where they are mounted to the fuel rail or regulator.
- x 8411
Hi David,
I'd suggest rather than a leak, you are running a very rich mixture. V6s do smell very "petroley" when cold and running rich.
First ports of call would be manifold leaks. On the Mk1 there is a blanked-off spigot on the rear (RH) side of the inlet manifold. The blanking cap often perishes and lets in air. Basically, any air leaks will upset the mixture as the mixture is under MAP control. It might be an idea to check the connector to the MAP sensor (rear of inlet manifold LH side) is nicely home.
Do you have a Lexia or access to one? It would be good to check the coolant temperature sensor is not telling the ECU porkies and keeping the mixture too rich.
DHallworth
- x 161
Hi Jim,
I've got a Lexia so I'll stick it on the car on Wednesday and see what I can find.
It's just the way that it smells worse after going round a corner or braking that made me think it was a leak.
I'm pretty sure it's got a vacuum leak now you mention it, the car has a habit of revving itself occasionally and it doesn't sound quite like it's running "right".
I'll have a good poke around and see what I can find when I'm next off work.
Thanks again!
David.
Thanks again!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
lexi
- x 133
The blanking plug that Jim speaks of was perished on mine David. It came away in my hand when I had a pull at it....I just made a new one. It sounds like overfueling. I am getting over 30mpg on the long runs mate with this one........... unless I am Chastising Chavs
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Clogzz
- x 40
DHallworth
- x 161
Clogzz
- x 40
- x 8411
Must say, in all the Xantiae I have owned over the years, none have had badly inaccurate fuel gauges. Mind you, in a V6 or an Activa the needle gets plenty of exercise so maybe that keeps it fit, a bit like Citarobics for fuel gauges...Clogzz wrote:Yes, it does, and I ran out of petrol twice without warning.the petrol pin on theirs talks gibberish?
Stempy
The only fuel leak I've had on the V6 was from a split hose where it connects to the injector rail, might be worth a look there.
Lexia ponce
Lexia ponce
spider
- x 77
Re: Hi
If your's is the 16v engine, the fuel pipes where they are around the timing belt (the plastic square joins) can leak here. There was a recall on some 406's actually for this from memory (same engine) although not many were effected, I think only a certain build code around 98.nejati2010 wrote:Hi,
I smell the same from my Citroen Xantia 2.0 (automatic) sometimes. How much is a normal consumption for these cars, so that I can check if mine is over-consuming or not. Can anyone tell please?
Andy.
VertVega
- x 13
Re: Hi
Sorry DHallworth, don't know about V6 but answering to nejati2010's post.
as a solution I replaced clips as seen in pic
Problem solved.
In mine, fuel pressure regulator hoses (on top of engine) leaked andnejati2010 wrote:I smell the same from my Citroen Xantia 2.0 (automatic) sometimes...
