Hydractive ECU
Toby_HDi
x 3
Unread post by Toby_HDi »
Dave, as Jim says, check everything else first. If you're electrovalves are buzzing and clicking I think its likely the VN05Ns are ok.
Maplin do not do the VN05Ns. If you need a couple RS electronics is where I got mine. I do have 2 left if you want though.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
davetherave
x 4
Unread post by davetherave »
Thanks toby, ill let you know!
Are 1n4001 diodes ok for the diode mod, i just happen to have 98 of them kicking about....
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
davetherave
x 4
Just been outside, and the electrovalves do click on when the door opens and click again about 30secs after the door is closed.
So that rules the electrovalves out!
Maybe its the sphere then!
GPZ500s
davetherave
x 4
After doing hte diode mod with 1n4001s, the car seems to be able to go over the bumbs ok again.
It still crashes over some, but i believe the diode mod must have done something, it now rides ok again!
So if i replace the sphere she should be floating!
GPZ500s
x 8170
Excellent news Dave!
