Citroen Relay
therealmadmax
Citroen Relay
Unread post by therealmadmax »
I have a relay 2.2 HDI and have found it increasingly difficult to get into 1st and 2nd gear, i had the cables replaced and all joints etc lubed last year. Any further help would be appreciated
spider
x 77
Unread post by spider »
Not at all familiar with these (although I have driven a few examples of them a few years ago)
My initial thought (as you said you've had the cables sorted) , can you select reverse OK ?
It does 'sound' like your clutch is dragging to be honest from the description (as that will make the lower gears difficult to select)
Andy.
