I have an X reg HDi Xantia, its done 160k miles
Just spent 150 on new front discs, pads and brake hoses to ensure it passes its MOT which is frankly 150 quid I haven't got.
Since it came back from the garage ive noticed that instead of the usual mildly heavy clutch operation, for 95% of the time when pressing in the clutch pedal I have about 2 inches of zero resistance and the clutch is now operated using the bottom half of the pedal. Sometimes there's what feels like a 'crack', almost like something plastic and flimsy has snapped under my foot if you know what I mean.
Im wondering (hoping) its the clutch cable needing adjustment rather than the clutch going. It doesnt seem to be slipping or popping out of gear or any other usual clutch wearing out symptoms but I am newish to Citroens and Im hoping that its just another one of their idiosyncrasies. The dreaded U shaped clip has been replaced sometime last year and the clutch is probably about 3 years old.
Im hoping you wont say its the clutch going but what do you think going on what I have said?
Also I have noticed my brake pedal is very close to the floor with not a lot of travel at all, compared with other xanitas. I can lift it up to what I consider a normal height but it crashes back down to near the bottom again once I let go. Is there any danger with this and can I adjust the brake pedal position? If so, how?
Bit of a long thread I know but once these are sorted I have a car I with almost no problems!!
Hi guys... need help with Xantia clutch - (but not the clip)
seany87
- x 94
firstly how light/heavy was the clutch pedel before the garage did the brakes,
the clutch bitting point should be no more than about half way up its travle from the floor boards,
what sort of miles has the 3 year old clutch done,
i dont think you will heve any adjustment on an X reg XANT as im sure it will be a self adjustting cable,
maybe its you clutch pedel is to hight not your brake pedel to low,
do the brakes seen to function corectly, light pressure for normal braking,
the brake pedel has a canister on the under side of it with a heavy spring inside, this is supposed to give you a pedel feel like none hydraulic car's brakes,
regards malcolm
regards malcolm
seany87
Hi Malcolmcitronut wrote:firstly how light/heavy was the clutch pedel before the garage did the brakes,
regards malcolm
The pedal was heavy before it was taken into the garage, I was told its a Xantia thing and I got used to it after a few days.
Clutch has probably done about 20-40k I would be surprised if its more than that. The biting point has remained the same its just theres no feel at all before I get to the biting point when I press the clutch in
Im sure the brake pedal should be higher as its the lowest pedal out of all of them and has about 1.5 inches of travel to the floor, but they work fine
HDI
- x 7
Xantia 2's have a hydraulic clutch , so there is no cable.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Xaccers
- x 188
hdi 110s have hydraulic, pretty sure hdi 90s don't.HDI wrote:Xantia 2's have a hydraulic clutch , so there is no cable.
After all, Cassy has a gearbox from a hdi 90
DIY sphere tool
DIY sphere tool
citroenxm
- Fallen Hero
- x 70
HDi 110bhp ARE Hydraulic clutches, 90 bhp are cable in the Xantias!
This did change however, as a mate has a 90 bhp 406 Estate and it too has hydraulic clutch...
So we can assume you have a HDi 90 Xantia then, which will be cable operated... anyway, it has to be, hydraulic clutches do not get heavy!!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
seany87
- x 1489
HDI
- x 7
citroenxm wrote:HDi 110bhp ARE Hydraulic clutches, 90 bhp are cable in the Xantias!
Paul
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Xaccers
- x 188
Auto adjusting cables were the silly thing.
I much prefer manual adjusting to auto or hydraulic.
It means I can have the bite point where I want it, ie down near the floor and a pedal that isn't trying to shake hands with the dashboard.
DIY sphere tool
DIY sphere tool
