Megane Dash
This is the Forum for all your Renault Technical Questions, Problems or Advice.
harryjoe
Megane Dash
Unread post by harryjoe »
Can anyone tell me ?
As to what would be the cause of the fuel guage and themp guage moving erratically, only in small movements like flicering, all other instruments are ok !, just these two,
I'm sure the fuel guage is not giving the correct reading, because of this !
Anyone
Nigel
1998 Xantia 1.8i 16v Auto (sold)
1997 Xantia 1.9 TD Estate (Resting with 231k) zzzzzz
1989 BX 19 RD (In a barn awaiting TLC)
2002 C5 2.2 HDI Auto Estate (Sold)
1994 XM 2.0 Turbo (Sold)
1983 Bertone X1/9 VS
1995 405 1.8 GLX Estate (sold)
2000 Xantia Estate 2l HDI 110K
uncle buck
x 10
Unread post by uncle buck »
Hi,
Does this problem happen all of the time or only when the temperature inside the car is low, like when the car has stood in the cold for a while?
Cheers.
2001 Xsara II 1.4 LX
harryjoe
Hi there,
It happens all the time, and they both flicker together at the same time !
Now the tank is low on fuel, it stays on the red !, but the temp guage still works as normal, but still flickers :roll: :roll: :roll:
Nigel
uncle buck
x 10
Hi,
if the problem is there all of the time it's not what I was thinking it could be...long story.
It sounds like a bad connection, could be a bad solder joint on the circuit board of the instrument cluster.
Take a look on the Renault forums, maybe someone else has suffered the same on their Megane.
http://www.renaultforums.co.uk/
Cheers.
harryjoe
Thanks Uncle !!! :wink:
Yes il'l do some ivestigation on this on the forum,
Quit annoying this little porblem, but you could be right about a dry joint, i know the Xantia suffrered a simular problem :?
French cars huh !! :wink:
BUT WE LOVE THEM :lol: :lol: :lol:
Regards
Nigel
