CITROEN PEUGEOT DUAL MASS FLYWHEEL DV6TED4
Big Jack
Unread post by Big Jack »
x 1434
110 quid for a USED DMF...well, there's one born every day I suppose....
TopDonkey
Unread post by TopDonkey »
Thats exactly what i was thinking too !!, you could pay all that money and fit it for it to fail next week !, best to buy new if your are changing a DMF used isnt worth it
x 1238
Unread post by Peter.N. »
..or run a car that doesn't use one :wink:
spider
x 77
Unread post by spider »
A thought:
Given the high cost of these DM flywheels, and I see other manufacturers are using them too as well
Is it possible to use a standard flywheel in its place if the need arises ?
TBH, It seems there's a 60/40 chance on a new flywheel being needed with a new clutch and its not cheap :(
XUD11 flywheel maybe to replace DW10 ? , just a thought, no idea if its actually possible.
I do not think myself the benefits of a DM flywheel outweigh the cost. Think how rare was it to change a flywheel (ring gear excepted) before the introduction of the DM ?
Just my random thoughts, nothing more.
Andy.
x 1044
Unread post by wheeler »
There are quite a few companies doing conversion kits now.
I know that Ford even sell a genuine part conversion kit for the transit.
Old-Guy
x 22
Unread post by Old-Guy »
There was a post back in December on this subject:
"Valeo .... are now supplying a DMF conversion. This kit is a complete clutch kit as per normal but has the benefit of also including a new flywheel, the flywheel is built to do away with the the "orrible" dual mass flywheel and the unreliability that comes with it, all of the dual mass benefits are still there as they are in the clutch itself, so next time it goes, the flywheel stays put and it's just a clutch change."
The topic referred to the 2.0 HDi (PSA) engine, but if Valeo have really cracked the problem, perhaps there are similar kits for other PSA/Ford engines? Has to be cheaper than 'genuine' flywheel and clutch; otherwise who would buy the Valeo kit. I imagine that use would invalidate a warranty, but for older vehicles that's an irrelevance.
Guy
flying clutchman
x 3
Unread post by flying clutchman »
Can confirm that the valeo kits work very well. Solid flywheel replacements are available from other manufacturers as well, but I am dubious about using these as some merely seem to be matching a solid flywheel with a suitable clutch kit. Valeo CLAIM to be doing something a bit more.
Citroenmad
x 110
Unread post by Citroenmad »
Our 52reg C5 HDi has had its DMF replaced with a solid flywheel. 50+K miles later and its still fine.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
