Honda is making an Activa
Koukku
x 8
Unread post by Koukku »
- Previously Activated -
x 8234
Well, at least you can be assured of never having ram problems on that Activa...
:roll:
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Not so sure on that; some people might try to fit more than one sheep on it...
Honda previously made the Lead - I always rhymed it with "dead" not "breed".
Deanxm
x 87
Unread post by Deanxm »
i hear its anti roll feature isnt as good as the Xantia's was though :lol:
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
TopDonkey
Unread post by TopDonkey »
7 BHP, do you think the chassis will be able to handle that much power ! :D
andmcit
x 30
Unread post by andmcit »
Seems cutting edge:
Suspension
Front: Bottom Link with spring loaded hydraulic damper
Rear: Unit swing with spring loaded hydraulic damper
has the word hydraulic in it!! :lol:
Andrew
x 1430
Unread post by xantia_v6 »
addo wrote:Not so sure on that; some people might try to fit more than one sheep on it...
They also made the "Lettuce" not so easy to rhyme :roll:
addo
x 95
But when you see one - do you start humming the Marseillaise - sorry - mayonnaise?
ACTIVE8
x 6
Unread post by ACTIVE8 »
Well here's a bigger Activa,
and you could use that small one as a run around for this one! :wink:
ACTIVA
Dommo
x 20
Unread post by Dommo »
I keep seeing those activa motorhomes whenever I look on ebay for a xantia activa!
andmcit
x 30
ACTIVE8 wrote:Well here's a bigger Activa
That wouldn't lean it corners too. Mind, that's simply because it so
damned big (as well as ugly) to actually go around one for this not
to even be a factor! :roll:
Andrew
