The C5 misbehaved today, by loudly beeping every second from under the dashboard.
It happened when I shut the driver’s door after getting in, and nothing would stop it.
I drove home like that, and it still beeped with the key out.
I fully opened the driver’s window and closed the door, then disconnected the battery for several minutes.
When I reconnected it, the noise was gone, and I didn’t touch anything for several more minutes.
When I started, everything worked normally.
Before the beeping, I fiddled with the display while on the move, to try to reset the consumption indicator, but got nowhere for lack of remembering how to.
Over the recent days, I also had derangement in the offside rear power window, with the rear window’s button on the driver’s door often working backwards, while the button on the rear door always worked normally.
Any inspiration welcome, and thanks for your troubles.
