Another "speared" Xantia strut top...Check YOURS!
citroenxm
- Fallen Hero
- x 70
bigblackfalco
- x 11
There's one on ebay now, but from pic, rubber looks a bit perished!
Think I'll take a look down my local scrappers, then I'll be able to get the spheres too!
Any ideas which tools I will need. Think I've read 24mm for the strut top nut?
If I remove sphere, complete strut should drop out bottom right?
Luckily I have a sphere removal tool
cheers.
cheers.
- x 8188
Yep, that's basically it
Remove sphere and pipe going to strut top. Pull the gaiter down.
Loosen the 24mm nut at the top but don't remove fully, just until the top of the nut is parallel with the top of the threads. Wallop the nut with a big hide hammer to break the taper and the strut will fall. Remove nut and pull strut fully out.
Then remove the four 13mm bolts and remove strut top.
Be preparted for plenty of LHM!
citroenxm
- Fallen Hero
- x 70
If you need strut tops and the strut to go with it from a S2 theres no need to take the strut top nut off... Get the whole lot.. Safer bet - of course if they want a stupid amount extra for the strut aswell, then its not worth it..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
I JUST WANT TO MAKE THIS CLEAR!
When I said Series 2 1998 onwards strut tops fit Series 1 cars, I meant the Top AND STRUT - I have no idea if theres a diamiter difference between S1 and S2 non hydractive struts.. I fitted both top and strut leg from a 1998 T reg SX, to my 1994 SX TD... no problem!
Struts are easy to remove, 16mm deep socket for the hub pinch bolt through the rear, cut the drop link, sphere off, 3.5mm feed pipe off with 8mm spanner, tap the hub off the bottom of the strut FIRST, then 4 13mm nuts to remove the strut top, and when you compress the strut you get covered in LHM if its facing you!!!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
bigblackfalco
- x 11
citroenxm
- Fallen Hero
- x 70
........ Top only....bigblackfalco wrote:OK, so it's either a complete series 2 strut or a new series one top strut.............!
cheers.
I didn't want to cause any confusion with what I had done or was saying..
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Martin Beevers
After nearly getting my Xantia sorted I hope this doesn't happen to mine...
On inspection my strut tops look in good condition, the only give away is the gaiters are at half mast and have been for quite a while. On reading through the posts I know that good ones can go pop too.
As GSF don't stock these parts I have been forced to get a quote from the main stealer, they quoted my £156.11 each, gaiters are £13 each plus I will need new seals and nuts too. What a rip off...
I may gamble and get a new bonnet from a scrappy and wait for it to happen.
Hopefully not at speed...
I'm not getting any noises/juddering on full lock.
95 Xantia 1.9TD SX - Now sold
citroenxm
- Fallen Hero
- x 70
Martin,
You dont really need new seals or nuts! Ive put S2 Xantia SX struts and tops on my S1 Xantia... never used any new seals or nuts either..
If you goto the scrappy, get a set of struts and tops from a S reg onwards car with small 3.5 feed pipes on them!
Regards
Paul
Regards
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Martin Beevers
citroenxm
- Fallen Hero
- x 70
Hi Martin,
No S2 Strut tops do not rot like earlyer ones... My tops have done about 250k now, and still looked extreamilly good! And ALL S2 ones ive seen have been like this..
Its not strut length I was worrying abouts more strut piston diamiter into strut top fitting, so to be safe, just fit the whole strut and top...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
addo
- Sara Watson's Stalker
- x 95
Martin Beevers
bigblackfalco
- x 11
citroenxm
- Fallen Hero
- x 70
