Peugeot 306 Rear subframe mounts
dandanfireman
Unread post by dandanfireman »
Hi there everyone, I know this has been mentioned many times on this forum but i've tried searching until i swear profusely and want to punch the laptop but still can't find anything on here about it unless i look on google and even then its an old thread with no decent info.
Please if anyone has any pics of a 306 rear subframe removal or similar as i know some of the citroens are the same it would be much appreciated. Any info would be greatly received aswell.
Dan
deian
Unread post by deian »
four bolts accessed from inside the boot, underneath the carpet/lining, rememeber to take off the brake lines / hb cables first.
should just drop down then
x 8391
Indeed it will Dei,
You beat me to it :D
Only other pint is that the back box may well have to be removed from the exhaust system. Certainly the case when I have done this job on 205s and they are very similar...
It's a very straightforward job.
Xaccers
x 188
Unread post by Xaccers »
CitroJim wrote: Only other pint
Perhaps the :beer: should be had once the job is done? :D
DIY sphere tool
deian
oh yes, forgot about the exhaust
x 1240
Unread post by Peter.N. »
I did one on a ZX, if this is the same, the bolts through the front mountings hold everything together, so don't try taking any short cuts like I did :oops:
x 1488
My thread about it is here:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=23055
Unfortunatley, geocities has closed, so the pics are no longer hosted, but if PM me your e-mail address I will send them on. Will get around to sticking them up somewhere else somewhen.
x 8391
The drink comes when you've successfully dismantled the rear beam and found it is salvagable :D
Maybe a drink too if the rear beam is beyond help :(
:lol: :lol:
