Citroen Xantia,High temp and no hot air
miggy24
Unread post by miggy24 »
Hi all well i just got a xantia and in traffi the temp gauge goes right up to 110 and when i turn the blowers on only cold air comes out so im guessing that theres an air lock somewhere.So can anyone please tell me how to bleed it all.Thanks
Xaccers
x 188
Unread post by Xaccers »
Which engine?
1.9TD, to the back left of the fuel pump there's a junction of 3 pipes with a coolant dust cap on top, remove the cap.
2.0CT back left of the crank case there's an elbow with a unscrewable bleed valve in it.
DIY sphere tool
miggy24
Hi its the 1.9td.Do the engine have to be running when doing this
x 8389
miggy24 wrote:Hi its the 1.9td.Do the engine have to be running when doing this
Yes.
Full procedure: Expansion cap off, run up to temperature, to the tank to brim, open the bleed cap on the three-way junction near/on the RH engine mount and the bleeder on the heater matrix elbow until clear, bubble-free water runs. Top up if necessary to keep the tank brimmed.
Feel all over the rad to check it's hot all over and feel the matrix pipes to check they're nice and hot.
Re-bleed if necessary.
Let run until the fans cut in and then out.
Switch off and leave expansion tank cap OFF until the engine and coolant have cooled right down. Top up if necessary and replace cap. Job done.
Xaccers
x 188
yes. engine running, bleed valve open, jug of coolant to top up.
when coolant comes out the valve, close it.
massage the large rubber hose along the front of the engine.
keep the engine running, you want the fans to kick in and the thermostat to open.
top up as needed
DIY sphere tool
miggy24
Ok thaks guys.Where can i find the bleeder on the heater matrix elbow
x 8389
miggy24 wrote:Ok thaks guys.Where can i find the bleeder on the heater matrix elbow
It looks like a tyre valve cap right on the elbow. It's hard to see but put your hand up there and you'll feel it. It's on the LH elbow if I remember correctly...
Be careful you don't screw it right off and loose it! Also mind the hot water...
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Its ok if you loose it, they are exactly the same as Tyre valve caps ! :wink: :D
Paul
A very sad...
1994 XM 2.1 d auto
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
citroenxm wrote:Its ok if you loose it, they are exactly the same as Tyre valve caps ! :wink: :D
Apart from the rubber seal inside at the end.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Clogzz
x 40
Unread post by Clogzz »
miggy24
Right well today i got loads of air out of the bleed nipple and the car temp is alot better and i have heat in the blowers.But i still wanna do the one to the heater matrix so my next q is where can i find the heater matrix elbow
Xantidote
x 4
Unread post by Xantidote »
Elbow is located/jammed right up against the bulkhead, at the back of the engine. The elbow's where the two rubber hoses terminate, and feeds the coolant thro' the bulkhead to the matrix, which is buried inside the car behind the dashboard
Martin
