ID this please?
lexi
- x 133
ID this please?
This was lying underneath V6 Xantia. Any ideas on function/location?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 8391
Oh Gawd, That's serious lexi. That's the "V" that makes it a V6..
You now have a Xantia 6
Seriously, not a scoobs
It looks like a hydraulic leakage return pipe joint from a distance but I cannot recall having seen one like that on the scrapper, Now the snow has more or less gone. I can look again.
Was it lying under the back or the front of the car?
andmcit
- x 30
If everything is still working I would suspect it's off another car.
Guess it depends where on the ground it was found; sainsbury's or
your front driveway! I've dismantled over half a dozen Xantiae now
and don't recall a pointless return Vee in this material, size or shape.
If it IS off your car it is specific to the V6 and as Jim says most
appropriately resembles the signature Vee... :?
Andrew
Andrew
lexi
- x 133
Thank s guys. Sure it`s off the V6. Was under the front /bulkhead area in spot where I was working. No other cars in this workspot for a month, I thought washer/wipe system but can see nothing amiss.
Without being geeky (I did) it`s a well made extrusion.
It may have been a fashion detail on some of those lovely designer cardys I wear while under cars
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
spider
- x 77
Water drain tube possibly ? (I can't make it out) , the kind of rubber tube you would get attached to somewhere on the body to allow rainwater to come out (think along the lines of the sunroof drain tubing)
Andy.
Trainman
- (Donor 2018)
- x 43
It looks to me that it was attached to someting if you look at the point of the "V" (bit like a piece of an airfix kit)
Steve
http://c6owners.org/index.php
lexi
- x 133
Ok water drain tube sounds good. The little bump at the V? That will be the injection moulding process ? All this geek talk.......let it be a secret
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
miked
- x 6
Re: ID this please?
It's called a tape measure. 10 foot Stanley by the look of it.lexi wrote:This was lying underneath V6 Xantia. Any ideas on function/location?
Sorry, I'll get my coat
andmcit
- x 30
- x 8391
Re: ID this please?
miked wrote: It's called a tape measure. 10 foot Stanley by the look of it.
Oh dear, that did make me laugh!!!
Good on 'yer Mike. I needed a good giggle
No need to get your coat....
lexi
- x 133
Code: Select all
10 foot Stanley by the look of itDon`t bother about location..........I`ve thought of a really good place for it.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
exect
DickieG
- Monaco's youngest playboy
- x 33
I reckon you're about right, the angle is too acute for a drain pipe.exect wrote:I dont think its anything to do with a car, I think its a joiner for the sicks of a kite or something like.
Exect
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
addo
- Sara Watson's Stalker
- x 95
andmcit
- x 30
