Hi all my c5 hdi 110 02 thinks its currently around 40c or 105f outside when its around 1c in reality,is the sensor easy to find and change and does the ecu rely on this reading for fuelling information as it could explain my mpg being around the 40mpg mark rather than a little higher?
While im here il drop another question regarding my drivers door window/electric mirror controller console,windows would go down on both sides but not up [well handy eh?]. Passenger side would go up with its door controller only and drivers side up on turning wipers on full speed, until one wet night when drivers side stay down until dismantled door card and placed in a wooden prop!! Im leaning toward replacing the drivers door switches from citroen dealer to hope that clears it up unless someone else can share a similar problem. One last thing for the moderators could the citroen forum have its own subdirectories to make finding car related problems more specific as currently searching is problematic due to getting all types of citroen model show up rather than just the model your looking for.{Not a complaint this is still the best forum}.
c5 temperature reading
mrlogik
c5 hdi 110 lx
Xantia hdi forte 140,000 [sold]
- x 1240
Simon99
Had similar problem with my passenger front window. Would go down with drivers door window control but only up by pressing passenger window switch. Popped out drivers door window control and took it apart and gave it a good clean. Seemed to be gunked up with maybe spilt soft drink (previous owner) and fluff. Works now good as new and was amazed at ease of fix.
Can confirm C5 temp sensor is on under side of passenger wing mirror. You can remove mirror glass by gently prising off with screwdriver from behind. This then gives you access to four (I think) plastic tabs which hold on colour coded main cover. These are bu**ers to remove but if you can get it off should be able to cut wires to temp sensor and remove. You may find it easier to remove whole wing mirror first but this involves first removing door card and inner trim.
2002 C5 2.0 16v Estate
2001 C5 2.2hdi Hatchback
1998 Xantia 1.9td Estate
- x 1938
Does anyone have spec for the just the temp sender?
I know people say they are cheap from the dealers but to me cheap is the 50p or so that just the sender would be from an electronics supplier!
Simon99
- x 1240
- x 1052
Onlinemyglaren
- x 5672
- x 1938
My point exactly!myglaren wrote:I believe that they are approximately £12 from the dealer.
mrlogik
thanks
Thanks for the prompt replies guys on both issues ill be prizing glass sometime soon,the c5 was pretty untidy when i got it and i still have the switches for the drivers door so they'l be dismantled and cleaned soon. Im surpsised the c5 doesnt take a temperature reading from somewhere outside for its fuelling though as most modern inject wether petrol or diesel?
c5 hdi 110 lx
- x 1052
- x 1938
It doesn't use the outside air temperature reading at startup for glow plug operation?
- x 1240
civvie
- x 20
A while back when mine was still under warranty I had the same problem of false reading. I took it into the dealer and he said it needs to be changed asap as the ecu uses the reading to run properly. They did it there and then.
Steve
Steve
Steve
C5 2.2hdi auto until I sell it (sold it) now have Peugeot 3008 1.6HDI (Now sold)
Had the jab a couple of days ago. Feb 21
- x 1052
Thats complete nonsense they told you.civvie wrote:A while back when mine was still under warranty I had the same problem of false reading. I took it into the dealer and he said it needs to be changed asap as the ecu uses the reading to run properly. They did it there and then.
Steve
The glowplug operation is controled depending on engine temperature (which it gets from the coolant temperature sensor).Paul-R wrote:It doesn't use the outside air temperature reading at startup for glow plug operation?
If you think about it the engine could be at 95 degrees but the outside air temp could still be minus 5, The engine certainly wouldnt need glowplugs on startup then.
