timing holes dont make sense!!! but sorted now cheers
spliffy
Unread post by spliffy »
hi all thanks for all your imput am right in asuming i need to lock off cam with no1 lobes facing up over the crank shaft im still a bit cloudy on iv followed the link for the xm formum and am i right asuming that i lock off crank via the fly wheel ignoring my crank pully (which is the one with the rubber)
Spliffy
have owned : renault 21,mk1 megane 1.6 8v
currently own renault megane grand scenic ( 1.9 dci privelige )
currently own renault megane coupe 1.6 16v
Deanxm
x 87
Unread post by Deanxm »
you can lock via the flywheel so long as its not auto, the trouble is on the turbo it can be a little trickey to get to so i always pull the crank pulley off and lock from there so you dont have to desturb the starter motor.
is the crank and cam locked as per the pictures on the how to file and yet your numbers 1 and 4 pistons are at tdc? or are they all at half mast as they should be now?.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
colinxm
Unread post by colinxm »
I don't know this engine but I wonder if it has the crank timing hole hidden behind the starter motor same as the 2.1 td models ? this allows a pin to pass through the engine casing and into the flywheel pulley to lock it all up with no doubts about it's timing, nice and easy with the starter removed or shoved sideways out of the way.
Just a thought, good luck Colin.P
1995 Cit XM 2,1 TD Silver Estate
2004 Pug 307 SW
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
spliffy
sorted now
cheers for all your help i got hold of a pulley (solid type) 0ff 205gti my timing hole on my shock type pulley were a mile out put solid type on she fired straight up
Spliffy
x 8417
That's excellent news Spliffy :D :D :D
Keep the pulley in your special tools box for use in the future :wink:
spliffy
i got hold of the above pulley my pulley was mile out compared cheers for advice dudes
Spliffy
