Engine management module
pckent
can anyone please tell me if a module from one xsara picasso 2001 model, fit into another picasso of the same year. I know it may need reprogramming, but will it work.
- x 1044
The ECU's can only be programed once only with the proper citroen diagnostic machine so even citroen wont be able to program a snd hand one for you. however I belive that there are people out there that can 'virginise' ECU's by messing about with the eproms & stuff inside them.
Have you got water in the ECU ?
pckent
ECU
hello Wheeler.
thank you for your reply. Yes I have moisture in the ECU. At the moment the only thing not working is the front windscreen wipers. Everything has been checked on this side of the car ie; motor, arms, fuses etc. Is there a way of drying it out or has the mositure destroyed some of the programming? I look forward to you reply.
Paul
Paul
- x 1044
