Obsolete electronics are going to be the deciding factor to scrap modern vehicles and the manufacturers love that !!
However , if there is enough demand , substitute electronic units could be designed to replace the originals. After all , when tuning cars , it is almost a given that an upgraded new , reprogrammable engine management ECU will be fitted. This is superior to the original in every case and the non race types are not really expensive in relation to their performance and facilities.
Problem is , that cars like Citroens are unlikely to provide an adequate demand for substitute electronics , unless an owners club commissions them.
VN05N removal (she's alive!)
HDI
- x 7
DickieG
- Monaco's youngest playboy
- x 33
Blast I was just about to ask you where the yard wasadmiral51 wrote:Sorry guys just been up the scrappy and the car has gone they crushed it along with a S1 TD![]()
Will keep an eye out in the future as i visit them quite often so if i can spot any ECUs/Relays especially from Hydractive/Automatics ill squirrel them away![]()
Colin
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1240
DickieG
- x 33
xmexclusive
Hi Peter
All suspension ECU's of H1 to H4 coding are model specific, the onboard Microcontroller is factory programmed using a EPROM programmer most likely before the chip is soldered to the PCB. Each variant has a seperate Citroen part number.
It is only H5 onwards suspension ECU's that are made as a blank universal unit. These have the later EEPROM Microcontroller which can be written to electrically to store a program for a specific car. Because of the type of Microcontroller chosen (write once) it can only be programmed a single time. The LEXIA can do this programming on a new blank ECU but not change the stored program on a secondhand unit.
Sadly there were very few H5 ECU's used as the blank Microcontrollers can be bought though the soldering job of replacement of a 64 pin device is not for the faint hearted.
John
John
Xmexclusive
- x 1240
deian
hi all,
right back to square one, whether that is good or bad, i have with me here paul's hydractive ecu, we put it on and it didn't work, no life at all, anyway, paul said see what you can do... so i took it and said i would open it up and have a look!
it is "100% IDENTICAL", the heat corrosion of the BUZ11 is EXACTLY the same, the hot (failed) VN05N is EXACTLY the same colour, same transistor too, it's always the top-est one, the one closest to the connector, now if I/we can work out which electrovalve that drives then maybe we can work out WHY it fails, surely it can't be a diode fail on both, it seems like one, and the same one. Even the blobs of glue are exactly the same size and shape.
Anyway, I will go back and carry on playing spot the difference, and decide whether to solder one transistor this time, VEEERRRY carefully using the weller iron this time.
Wish me luck!
Wish me luck!
- x 8409
Luck wished Deideian wrote: Wish me luck!
Must be something in the Anglesea air that's killing the ECUs
I don't know if this will help determine which VN05 does what but here's a typical circuit of the hydractive system.
The electrovalves are items 7716 and 7717, 7716 being the front one...
- x 1240
DickieG
- x 33
And for number three,deian wrote:it is "100% IDENTICAL", the heat corrosion of the BUZ11 is EXACTLY the same, the hot (failed) VN05N is EXACTLY the same colour, same transistor too, it's always the top-est one, the one closest to the connector, now if I/we can work out which electrovalve that drives then maybe we can work out WHY it fails, surely it can't be a diode fail on both, it seems like one, and the same one. Even the blobs of glue are exactly the same size and shape.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
xmexclusive
On the PCB photo that Dien originally put up the VN05N nearest the white connector drives the front electrovalve via pin 1 of the connector. The VN05N furthest away from the connector drives the rear electrovalve via pin 2 of the connector.
Have done a bit more circuit tracing on the scrap ECU that I have here.
There does not seem to be the direct connection that I expected between the BUZ11 and the VN05N electrovalve drivers.
The inputs (pin2) of the VN05N's are driven directly each by seperate output lines running from the TMS3700056 Microcontroller. This suggests that BUZ11 burn out is not directly related to VN05N burn out. If this was the current feed the fine circuit tracks and the Microcontroller internals would burn up long before the sort of damage we are seeing could be inflicted on the VN05N's and the BUZ11.
I have now also traced the output of the third VN05N. This goes to pin 9 of the Black plug. Can anyone confirm that this is the pin that drives the third electrovalve on an Xantia Activa?
John
John
Xmexclusive
deian
thanks for the wiring diagram jim,
so richard has a top one damaged too, i rekcon it could be the back electrovalve, the frying could be due to the distance the sine wave travels down the cable from front to the back of the car and may get interference from other sources along the way, hence the transistor working harder?
i'm doing just the one this time, and i am puttins less solder in it, and no drilling the holes clean, i will try to reuse the existing solder
DickieG
- x 33
- x 1240
Hi Deian
You really need fresh solder because the flux will have evaporated, you need a hot, clean iron, place it it on the connection and either remove the solder with a solder sucker or move the board rapidly so that it flies off. When resoldering, apply the heat to the joint not the solder, when hot apply the solder and it should run neatly into the joint with no overspill.
Its important that the metal you are soldering to is at the melting temperature of the solder before you apply it, dont worry about the heat on the components, they are designed to stand it. The hotter and cleaner the iron, the less time you need it in contact to bring the temperature up.
