My 1.9 TD 406 has become difficult to start when it's cold, i'm pretty sure it's glow plug related , if i keep turning it over it starts eventually.
What i need to know is, is there a fuse or a relay that i can check?
I'm pretty sure the glow plugs themselves are ok because the car started fine in the morning in the snow but started to struggle when i came out after work, it's as though none of them are heating up hence my thought that it's a fuse or relay.
1.9 TD Starting Problems
- x 8263
One thing that can cause hard starting in very cold weather on these engines is tight valve clearances. It's a quirk of the XUD that the valve clearances are tightest when the engine is stone-cold. If they're marginal at normal temperatures then when it's really cold, the clearances can go negative, hold a valve or two marginally off its seat and make starting very hard.
1.7 XUDs suffer from this badly. 1.9TDs not so badly but if the glowplugs check out OK and starting is generally fine when it gets warmer, it's worth a check.
Breedsey
mark21td
I thought the XUD's had hydrolic lifters.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
- x 8263
Pleased you found the problem Breedsey
Fingers crossed...
Fun job to re-shim them, or at least it is to calculate the shims you need although I have an Excel spreadsheet to help do the maths...
No, only the 2.1 (XUD11) Mark, all other XUDs (and 8V XUs) have inverted buckets and shims...mark21td wrote:I thought the XUD's had hydrolic lifters.
