2 little known features of Xantia's , I think !!
lexi
x 134
Unread post by lexi »
So what is the steel wrench type thing stuck in the bonnet towards the window on V6 mk1 ? I haven`t had time to pull out for a look as been doing other stuff.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Not seen that on mine????
PAul
A very sad...
1994 XM 2.1 d auto
Toby_HDi
x 3
Unread post by Toby_HDi »
Jim, I'm positive your V6 has the indexed mirror.
I clearly remember it moving when you took me for a spin in it.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
x 8309
lexi wrote:So what is the steel wrench type thing stuck in the bonnet towards the window on V6 mk1 ? I haven`t had time to pull out for a look as been doing other stuff.
If it's in the passenger side corner and the back, that'll most likely be the towing eye. Some were located there and other times they were packed in with the jack in the spare wheel...
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Is it the tool with a loop on one end and a thread on the other? If so it's a tow hook.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8309
Toby_HDi wrote: I clearly remember it moving when you took me for a spin in it.
Thanks Toby :D :lol: That's brilliant!
Guess I'd better make a new years resolution to visit the optician then. Never noticed it :roll: :lol: :lol:
HDI
x 7
Unread post by HDI »
I'd had my Exclusive for a year before I noticed it :oops:
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Bruce H parted out a non-dipping, single airbag Exclusive (Series II). So, they do exist!
I joked it was "exclusive" of the features one came to expect.
Has anyone experimented to see if the motor unit can be transplanted between dipping and non-dipping mirror shells? I mean the inner bit which is about size/shape of a boot polish tin.
Citroenmad
x 110
Unread post by Citroenmad »
Dipping mirror is a great idea, the VSX Xm has that, very handy that you can adjust it when in reverse. I often adjust it for parking next to curbs.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1438
Unread post by xantia_v6 »
addo wrote: Has anyone experimented to see if the motor unit can be transplanted between dipping and non-dipping mirror shells? I mean the inner bit which is about size/shape of a boot polish tin.
Yes, I have converted a non-dipping to dipping to reinstate the dipability on my Mk2 Xantia. The wiring needs to be swapped over, which is a bit tricky.
Mk1 and Mk2 dipping mirrors have different means of connection to the boot polish tin, the Mk1 being soldered (you can only get to one side of the PCB), and the Mk2 having a convenient multi-way connector (which is not compatible with a Mk2 non-dipping mirror).
The boot polish tin is interchangable with one from a Jaguar XJ40 (soldered connections like the Mk1), but you need to cut a couple of tracks on the PCB, as they have different wire links fitted (and as above, you can only get to one side).
addo
x 95
C'est interessant. My non-dipping X2 mirror (now replaced with Bruce H's non-dipping Exclusive one) has a three pin socket on the "boot polish tin"; are you saying the dipper has a different plug again?
One (non-mirror Q) that confounded me: I found yet another redundant plug in the harness. It's on the driver's side of the front footwells, strapped with foam tape to the main cross-car harness. Two pin plug, with largeish terminals, reddy-brown in colour. I wondered if manual cars have any switches on the clutch pedal.
x 1438
addo wrote:C'est interessant. My non-dipping X2 mirror (now replaced with Bruce H's non-dipping Exclusive one) has a three pin socket on the "boot polish tin"; are you saying the dipper has a different plug again?
Yes, it has an 8 way connector (standard 2x4 0.1" square pin format). Plus 2 for the heated mirror, plus 2 for the temperature sensor, makes 12 wires all together (the Mk1 only has 10 because the temperature sensor is on the other side).
deian
Unread post by deian »
Isn't that the diagnostic plug?
citroenxm
Fallen Hero
x 70
Not hidden I doubt it.. it will be for something thats obviously not fitted to your car but the car used a "Standard" harness..It could be a plug for electric seats, or even the headted elements..
Actually, it could even be the connector from the brake switch for the CRUISE CONTROL knock off when the brake pedal has the cruise switch fitted..
just a guess..
Paul
A very sad...
1994 XM 2.1 d auto
addo
x 95
I've got factory cruise; it's switched from the brake pedal. Diagnostic plug is over the other side.
I'll pull some numbers off the wires today...
