How many knew this ?
The bonnet can be opened upto and past vertical for better service access ? Don't do it in windy conditions though , it only rests against the stops in the just past vertical position and will blow shut quite easily !! Although I've made an extra long support strut to use in such conditions !!
The passenger side door mirror dips when reverse is selected to allow better vision. The dip position can be adjusted too !!
Now , could someone answer this Xantia question please , what is the faint temporary whistling noise after the car is locked ? Not referring to the auxiliary heater spool down.
2 little known features of Xantia's , I think !!
HDI
- x 7
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 8437
Re: 2 little known features of Xantia's , I think !!
I know that one! Only way to give sufficient room to lift out a V6 engine/transmissionHDI wrote: The bonnet can be opened upto and past vertical for better service access ?
- x 1476
Only on "Exclusive" specification, and if you bust the mirror, a new replacement is about £250.HDI wrote:How many knew this ?
Is that the Hydroactive valves whistling?HDI wrote: Now , could someone answer this Xantia question please , what is the faint temporary whistling noise after the car is locked ? Not referring to the auxiliary heater spool down.
deian
citroenxm
- Fallen Hero
- x 70
Always knew about bonnet positions.
Dipping mirrors are ONLY on Exclusive models ONLY, including Series 1 V6 (Which introduced the Exclusive spec)
(S2 SX cars DO NOT do it)
The whistle noise is the locking mechanisems just groaning inside the locks, as they are built into the locks, unlike earlyer cars like the BX where as the lock solinoids are seperate to the door locks..
Waffle waffle waffle, sorry.. something like that anyway.. Mine makes some very loud awfull noises, but always locks so far...
Oh, the filler cap and Boot still use seperate solinoids, its just the main 4 door locks Im on about...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8437
Not on minecitroenxm wrote: Dipping mirrors are ONLY on Exclusive models ONLY, including Series 1 V6 (Which introduced the Exclusive spec)
So, Activas (S1 included) with the Winter Pack should have a dipping mirror...
DickieG
- Monaco's youngest playboy
- x 33
The dipping N/S mirror was available as standard to any Xantia fitted with electric seats and the winter pack at the factory, which includes any VSX or Activa.
With regard to the bonnet tilt position on Xantia's I think Citroën made a special tool to hold the stay in the further rearwards position.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
citroenxm
- Fallen Hero
- x 70
Dont think anyone has ever mentioned dipping mirror in Xantia ACTIVAS before, hence me not knowing that..
Did VSX's get electric leather seats, or just manual Leather...?
Jim, she WILL be dipping if my P Plate V6 has it, your certainly will
It will ONLY move if you re position the mirror WHILE your in REVERSE, then it will go back if you take it out of gear...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DickieG
- x 33
Have you checked it Jim?CitroJim wrote:Not on minecitroenxm wrote: Dipping mirrors are ONLY on Exclusive models ONLY, including Series 1 V6 (Which introduced the Exclusive spec)![]()
But then it is a "poverty spec."
Unless someone has re-positioned the mirror whilst reversing, the mirror will still be in the standard position from the factory. I've come across a few Xantia's and an XM like that.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
HDI
- x 7
Great !! If it fails I'll just live without it I think !! No doubt it has an ECU to control it too !!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
hirsty
- x 9
DickieG
- x 33
YepHDI wrote:No doubt it has an ECU to control it too !!
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
HDI
- x 7
- x 8437
I thought I'd tried adjusting the mirror whilst in reverse but it may have been a dream
I shall try again...
And another odd mirror fact. If you should replace a standard N/S electric mirror with a dipping one by mistake, you'll find it really moves fast on the controller, almost too fast
That's most likely the reason Keithhirsty wrote:If you disconnect the battery, the dipping mirror reverts to standard position. I only found this out after putting on a new battery.
Chlorate
