Hard rear supension
x 1240
Unread post by Peter.N. »
Are your front rear tyres exactly the same?
XantiaDaveEire
x 4
Unread post by XantiaDaveEire »
not too sure peter..what pressures would you advise?
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k #-o
x 1240
Don't know about the Xantia, but reducing the pressure on the XM from 33 to 30 makes a significant difference, as does the type of tyre.
falling-out-with-my-car
x 25
Just been out in that horrible icey snow for a gander at my xantia doorpillar tyre pressures for the front are 30 and rear are 34
if the car is fully loaded (and I dont mean silly boy racer rubbish all over it) the rear should be 38 psi.
hope this helps
regards Nigel.
Xaccers
x 188
Unread post by Xaccers »
shirley you mean 34 front, 30 rear? :)
DIY sphere tool
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Xac wrote:shirley you mean 34 front, 30 rear? :)
Depends on the model, all three of my Xantia's have different specified pressures.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Xaccers
x 188
All the Xantia tyre pressure charts I've seen have higher on the front than the rear
DIY sphere tool
DickieG
x 33
Xac wrote:All the Xantia tyre pressure charts I've seen have higher on the front than the rear
True :roll:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 1240
Likewise with the XM, hatch 33 front 28 rear. The estate is 33 front and rear, as its considerably heavier
XantiaDaveEire
x 4
currently i have the front at 33 and the rear at 30..i might put the rears down to 28/29 and see if this helps me :roll:
vince
x 13
Unread post by vince »
XantiaDaveEire wrote:front hydractive part number 527240
rear non hydractive N45366
Dave, which branch of GSF did you get your spheres from?......
On all AMTEX spheres the part number is written on the sphere itself. Dont go off the number on your invoice or the number on the box. They are easily mixed up.....Customers sometimes return goods in the wrong boxes. These can then eaisly be missed when putting them back in stock...results wrong part dispatched in the right box or vice versa :wink:
Double check the numbers if you can on the spheres and call GSF to ask them whether they are hydractive or non :wink:
XantiaDaveEire
x 4
Hi vince ,i bought them online as there much cheaper than buying them here :lol: ..they specified that they were non-hydractive and asked me to confirm it twice..now that i think of it GSF heathrow was on the invoice im nearly sure of it :roll: ..the threads and bores were the same as the spheres i took off ..il just have to accept it i guess :cry:
x 25
Nope checked again in dayl;ight and the front is 30 and the rear is 34, mind you mines an estate (shirley). :D
x 1472
Unread post by xantia_v6 »
XantiaDaveEire wrote:.il just have to accept it i guess :cry:
You could read the numbers off the spheres, as a second option... :-k
Xaccers
x 188
Bizarre, Cassy, Dex, and my old LX, as with my hatchbacks, and all the charts I've seen have higher on the front than the rear. With only 30 on the front they'd look really flat, as it is with 34-36 psi fronts on a Xantia look under inflated anyway.
DIY sphere tool
