Accumulator sphere question ?
HDI
x 7
Unread post by HDI »
Some may have seen that I have an intermittent problem with the rear suspension going hard and a repeatedly bursting hydraulic feed from the pump. Today I was reminded of something that may be relevant to diagnosing the problem. Normally after starting for the first time in the day I wait for 20 or 30 secs for the suspension to level out , if I ever need to drive away almost immediately the brakes don't work and the steering is heavy. If I wait this doesn't happen. Could this be a sign of a faulty accumulator sphere ?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 1240
Unread post by Peter.N. »
That would seem to indicate the exact opposite, that the pressure is not coming up until the sphere is charged, but, there should be enough pressure to make the brakes work as soon as you start so it would appear that the pump output is low, the first thing to check though would be the pump belt tension, sounds to me as though its slipping.
I would certainly change the accumulator sphere though, it much easier than fitting another pipe and cheaper!
HDI
x 7
Belt tension is fine , I installed a new one a few months ago. I was thinking that if the accumulator isn't retaining pressure this could cause the problem. But then the pump isn't clicking excessively.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1240
If the pump isn't clicking fairly frequently that would seem to indicate that the sphere is OK, but having no brakes at start up definitly indicates a problem, mine come up if you just operate the starter. The slow suspension rise could be a red herring, there are a number of things that could cause it. If the steering is heavy that definitly indicates lack of pump output, if you only recently fitted the belt it may need tensioning again, if its not that, either the pump or the regulator is faulty.
x 5672
Worth checking the filters in the reservoir.
Is the LHM dirty? - dose of hydrorincage may be called for.
x 1240
True, that's something I overlooked.
HDI
x 7
Won't be that , it's had at least 6 lots of new LHM this year do to the pipe bursting problem !! Now I run it with just enough to keep the warning light off , about 2 ltrs !!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1240
Pump or regulator then. Pump's favourite.
XantiaDaveEire
x 4
Unread post by XantiaDaveEire »
would the amount of LHM in the resevoir be any cause for concern?
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k #-o
x 1240
Not unless its very low.
XantiaDaveEire
x 4
very low as in less than 2 litres? :?
x 1240
Certainly
HDI
x 7
Won't cause a problem except for possibly in very hot weather , then 2 ltrs may become a bit too hot.
I'm doubting the pump is the problem , suspension rises as quickly as any Citroen I've known and after this initial cold start time everything is fine.
Can the reg be examined and what is likely to be wrong with it ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
HDI wrote:Can the reg be examined and what is likely to be wrong with it ?
Yes by attaching a gauge to it and reading the outlet pressure, over time the springs inside become weak, take a look at my recent blog entry for further info/pictures.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1240
The only other thing that can give those symptoms that I can think of is a slipping belt, otherwise I am mystified.
