What could be causing this ?the accumulator sphere?All the LHM in the system is stilll a healthy green..
Hard rear supension
XantiaDaveEire
- x 4
Hard rear supension
So after changing the rear spheres and topping up on LHM and doing a good round of citrobics i dont notice any differance in comfort ,if anything the rear feels even harder
..the only thing i can say is that it self levels a little bit quicker
... And if that wasnt enough my heater blower has a mind of its own just recently,working sometimes but more often than not theres not a kick out of her
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k
mark21td
Is it a VSX (hydractive), if so you may have some valve trouble.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
XantiaDaveEire
- x 4
DickieG
- Monaco's youngest playboy
- x 38
Where did you get the sphere's from and what part number's are they? I suspect you have Hydractive sphere's on a non-Hydractive car.
Re the heater fan are you having problems at any set speed or just on auto? Is the motor running but little output from the vents or is the motor just not running?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
mark21td
Ooh, have they given you the right spheres, if you got hydractive ones then there harder than normal ones.XantiaDaveEire wrote:nope shes a non - hydractive
If you can post the part numbers up and I'm sure someone will tell you if there the right ones or not.
DickyG you type quicker than I do
XantiaDaveEire
- x 4
they are non hydractive spheres ,i dont have the parts numbers to hand but i bought them off GSF i have hydractive spheres on the front which works a treat..this wouldnt cause any trouble surely?
As for the heater
there is not a kick out of it on all settings ..it was working yesterday when i got into the car,went into the shop ,came back out and nothing from it ..its been like this recently working very rarely
Dave
As for the heater
Dave
- x 1458
DickieG
- x 38
As mentioned above Hydractive front sphere's on a non Hydractive car will give a harsh ride.
With the heater fan, check the connection of the large red wire onto the motor, it carries a large current and is prone to corrosion.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
XantiaDaveEire
- x 4
XantiaDaveEire
- x 4
- x 1240
Check your suspension movement by bouncing the rear, you should have "4 - 6" of movement with new spheres, if you havn't either the spheres are faulty or the ride height is not correct and its hitting the bump stops.
It doesn't state on the GSF list on the internet whether 45366 is hydractive or not.
XantiaDaveEire
- x 4
XantiaDaveEire
- x 4
all tyres ,pressure everything is fine...does the accumulator sphere control the pressure for the whole car as i suspect that this needs replacing ,but the front is soft and only the rear is hard...so frustrating
..feels like the tyres are over inflated
- x 1240
