Does the bearing look melted through lack of lube, or is there any sign of contamination?CitroJim wrote: In the event the converter did come off and left the bearing and oil seal in place but close examination of the TC neck and bearing shows damage similar to what we found in xantia_v6's gearbox but less severe.
- x 1473
- x 8423
Just yet Mike, because of the stator extension being in the way, it's hard to see the bearing clearly but it looks a bit like a big end shell that's been "run"
More will be known as soon as I split the 'box to see what else has failed.
Lubrication failure does seem the likely cause but not due to Dexron directly. What was in there was very new.
I'd have loved to have seen (and smelt) the old oil.
DickieG
- Monaco's youngest playboy
- x 33
mark21td
Jim, has the Lucas epic gone back together ?
I've been trying to keep up with your blog but it gets so many posts I may have missed it.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
- x 8423
Yes, it has but only on a temporary basis. I had it all in bits back along and then I was called up for gearbox work which is still sort of ongoing.mark21td wrote:Jim, has the Lucas epic gone back together ?
As soon as time permits, I'll get back to it Mark. Upshot was that the pump, apart from being a bit gunged up, was in fine condition and after a rebuild should run again fine.
lexi
- x 133
It`s no wonder cars weigh so much when you look at cutaway of V6 engine bay. I don`t know how I have managed to get my big hands anywhere in between that stuff in last few weeks
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
mark21td
AH so Ididn't miss a post then, I hope that when it's back together it'll be put to good use one day and save a 2.1 from the crusher.CitroJim wrote:Yes, it has but only on a temporary basis. I had it all in bits back along and then I was called up for gearbox work which is still sort of ongoing.mark21td wrote:Jim, has the Lucas epic gone back together ?
- x 8423
Spannering therapy was called for this evening
It's been an excellent week really, totally different to last. The forum seems to be happy on its new server and work has gone very well. I scored a personal triumph this week by really getting to grips with a piece of software I have been tasked to become very familiar with. It's an incredibly complex thing called Mirror42 and it's used to generate our Key Performance Indicators (KPIs) and tell management how well we do our work
The name of this software was inspired by the Hitch Hikers Guide to the Galaxy and the computer called Deep Thought that took 7 million years to work out the the answer to life, the universe and everything was 42. Mirror42 will give you the answer to life, the universe and everything but like Deep Thought you have to know how and what to ask it; that's my job...
Enough of that. Tonight curiosity got the better of me and I pulled the gearbox from the scrapped V6 apart. Some bolts were incredibly tight and corroded and I broke my T40 Torx bit on one of them
Finally, it yielded and it came apart.
The 'box was still working (just) but was whining very badly and the torque converter neck had welded itself to its bearing.
Inside, apart from the bad bearing, there is nothing the matter. Everything is serviceable, including the oil pump except for the aforesaid bearing and maybe the torque converter.
The failure was caused by lubrication failure resulting from a clogged oil filter. The filter is so clogged, oil will barely run through it.
So,a refurbished converter, a converter bearing, a filter and a gasket set and the 'box will be good to go again despite it's brush with a fill of Dexron
Cost circa £250 to make it good again.
Here's a shot of the failed converter neck bearing.
Scoring and fretting can be seen. It's like a big end shell in construction. basically a soft bearing surface on a steel backing. The soft stuff is mangled and mostly gone. It welded to the TC neck and the steel under part has spun badly in its housing - hence the noise.
So, again, at say 120,000 miles and no record of regular oil changes, if you want your V6 gearbox to carry on living, whip the engine out, split the gearbox (no special tools needed) and replace that filter. Cost about £50 with gaskets.
- x 8423
DickieG
- x 33
XantiaMan
- x 18
I'm a fan of ROTFLMFAO.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
2017 Fiesta ST
- x 8423
Sl4yer
There's definitely an alternative career in autobox repair for you Jim. Shame they're not designed to make a fluid and filter change simple, although that's probably not by accident.
Computer systems at my employer seem to work on a SISO basis, IYKWIM!
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
- x 1473
Good work Jim.CitroJim wrote: The failure was caused by lubrication failure resulting from a clogged oil filter. The filter is so clogged, oil will barely run through it.
Those bearings need oil pressure to operate, so maybe the filter got to the satate where there was 0 pressure at idle, and that killed the bearing?
That could be almost independent of the original symptom (lack of forward drive) caused by lack of pressure at higher revs?
BTW, what is the filter clogged with, and where did it come from?
lexi
- x 133
Excellent stuff Jim. Apart from whipping out box it must still do some good to change out oil anyway?. That oil is usually carring fine particles around.
Those HP422 AND HP424 Boxes in Landrover can be sump pan dropped and filter changed. They also run on Dexron. Tell me this? Is it possible that ZF merely changed the lube spec on 20 box to the Esso semi synth because they knew it would be in for life?
Or would that box have run with Dexron from the factory at new? Obviously you cannot use Dexron but would that be more to do with the mixing issue? I am just curious as to the difference between these similar high tech ZF boxes which take Dexron and our 4HP20 that don't.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
