Xantia II Hydractive Circuit Diagrams
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Jim - any chance you would be able to load up the trio (location, schematic, symbolic) for Series II? I've saved the Activa ones you previously posted, but want to check some details against regular Hydractive II setout.
Thanks, Adam.
x 8411
Hi Adam,
Yes, no problem at all. Will do that later this evening :)
AbangCorp
Unread post by AbangCorp »
gosh
this seems interesting
addo
x 95
It is interesting! :lol:
• If Jim can find a few minutes to post up the other diagrams, I suspect there will be only one wire different - 7723, which goes from Pin 9 on the white suspension ECU plug to the Activa electrovalve (part #7718 on the Activa diagrams). The companion wire on that plug is a ground, spliced into the bolt-down ground terminal near the RH strut like all others.
• A resourceful person could probably modify the white ECU plug to accommodate this extra wire. As the plug's rear is encased in a sort of polyurethane/rubber sealant this would not be fast or easy.
• It seems reasonable to assume that the suspension ECUs are also extremely alike; Hydractive and Activa share the same inputs from identical components. I would not be surprised if the extra driver transistor(s) and other related components could be added, and the ECU re-flashed to Activa spec.
Yes, I am aware that the Activa harness/ECU has a different plug to prevent installing in a regular Hydractive setup, but perhaps (for the hobbyists) we are now looking at ways around this...
x 8411
addo wrote: • A resourceful person could probably modify the white ECU plug to accommodate this extra wire. As the plug's rear is encased in a sort of polyurethane/rubber sealant this would not be fast or easy.
Ahh, it's a lovely thought Adam and even though the solder pads on the PCB exist for the additional VN05 switch for the Activa stiffness regulator electrovalve, it won't work as the ECUs are one-time programmable only. If it's previously been programmed as a standard Hydractive ECU it can't be reprogrammed again to become an Activa ECU :(
Here's the circuits of the standard Hydractive setup...
MK2 Hydractive Circuit
MK2 Hydractive Harnesses
MK2 Hydractive Component Locations
Sorry one is a bit on the tilt :roll: If I was scanning Activa circuits they'd have kept on the level :lol:
addo
x 95
Ta for that - all filed away now! :twisted:
This "non-rewritable" bit puzzles me. After all, quite a good number of people seem to make a habit of cracking software and overwriting stuff. The boxes are NFP now, so I'd have thought the need was gently rising...
Regards, Adam.
x 8411
I'm sure if you put a really top-notch electronics whizzkid onto the job Adam, it could be done. I guess it all depends on what sort of PROM they have in them..
The Lexia won't reprogram them but that's not to say they definitely can't be of course but I don't know how to approach such a job unfortunately. The only electronics I'm really happy with and totally knowledgeable of has those quaint glass tubes called valves that glow in the dark.. Black, multi-legged devices on PCBs I never quite got the full hang of :twisted:
Another difference with the pukka Activa ECU is that the black connector is replaced by a green one with different keyways.
I've used (as a test only) an Activa ECU in place of a standard Hydractive ECU buy gently cutting off the offending keyway. It works but I never ventured out on the road with it fitted.
addo
x 95
You'd think the electronics required to drive it, if built solely with vacuum tube technology, might load up a decent sized box trailer nicely! :lol: Or are 6L6s a straight swap for VN505s?
We're probably only a year or two from the point where a "prestige" maker has ICE featuring visible amplifier valves behind a glass screen in the console, just for the J Arthur factor. I'd say all that's stopping them so far is adequate shielding...
Jumping back to the present for now - I note the rear Activa electrovalve has a different part number - did you test the drive frequency/amplitude of this output during the probings some months back? Have to wonder if it's just spec'd different because of a different plug indexing slot.
Cheers, Adam.
x 8411
addo wrote:I note the rear Activa electrovalve has a different part number
Ahh, now that's interesting Adam. All I do know is the Activa Electrovalve works in the opposite sense to the Hydractive ones. When the Activa electrovale is de-engergised the system is in "soft" roll correction mode as apposed to the hydractive ones that set hard mode when de-energised so maybe the electrovalve works in reverse to achieve this.
I'll have a gander next time I'm in the ECU box with a 'scope and I think I have an Activa sphere block knocking around so I'll have a look at the electrovalve.
addo wrote:You'd think the electronics required to drive it, if built solely with vacuum tube technology, might load up a decent sized box trailer nicely!
There was a valved fuel injection system marketed in the USA briefly back in the 50s, I believe called the Electrojector and made by Bendix. Likely that had a nice row of 6L6s driving the injectors :lol: Must have been quite a task to generate the required HT for that lot though. Needless to say, it was not a success, not because it used valves so much but because the wax/paper capacitors had a tendency to develop leakage.
It seems bad enough waiting for IDI diesel glowplugs to do their thing but imagine having to wait for a valved fuel injection system to warm up before starting up!!!
Valved ICE in cars :twisted: You just know it will happen one day!!!
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
addo wrote:Jumping back to the present for now - I note the rear Activa electrovalve has a different part number - did you test the drive frequency/amplitude of this output during the probings some months back? Have to wonder if it's just spec'd different because of a different plug indexing slot.
The rear balancing electrovalve on an Activa works in reverse to the normal Hydractive blocks. i.e. normal Hydractive blocks default to firm whereas the Activa one goes to soft.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8411
Richard, sorry :oops: We must have both been bashing the keys at the same time there....
DickieG
x 33
You beat me to it Jim. :lol:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
DickieG
x 33
Bloody hell that's twice in quick succession!! :lol: :roll: :lol:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
addo
x 95
I'm sort of bummed out the Activa electrovalve's a different beast by nature of its reverse operation. It crimps my local scrounging opportunities. :lol:
x 8411
addo wrote:I'm sort of bummed out the Activa electrovalve's a different beast by nature of its reverse operation. It crimps my local scrounging opportunities. :lol:
You could always invert the signal to it Adam. A 6L6 would do that a treat :lol:
