Hello,
Hope someone has some advice. My kangoo keeps turning over at start up and will not start till I pump the fuel primer. Sometimes takes a lot of pumping to get it started and sometimes starts straight away. I have changed the fuel filter, and can't see any leak in the hoses. Can anyone tell me what else it might be?
thanks in advance
Rob
Renault Kangoo van starting problems....fuel I think?
robzondrumz
- x 5679
robzondrumz
- x 5679
evilally
- x 3
Yep, sounds like a leak in the fuel line. The fuel is probably running back to the tank when it's been sitting.
2 ways I've checked for leaks in the past:
Replace a section of hose with transparent line and then look for air bubbles. Replacing one section at a time, work your way backwards to find which component is leaking.
...or....
Fit a tyre valve to the end of the fuel line, and then put it under a bit of pressure with a foot pump or whatever. That should make the leak obvious. If you can get an electronic one with a pressure read out, then you can check that the fuel system holds it's pressure, then you know there are no leaks anywhere
Obviously don't go mad with the PSI
...or....
'96 405 1.6 GLX with 306 GTI engine on Cat cams @ 195bhp
'05 RenaultSport Clio 182 Cup, 102k
'97 406 1.9TD, 314k.
