HOW DO I OPEN A C5 KEY TO REPLACE BATTERY???
chris050
Unread post by chris050 »
Anyone know how I can do this? the remote function suddenly stopped working today. it may not be a battery issue but I thought I'd try that first.
many thanks
x 5674
Often wondered that myself.
Mine stopped working last week but opening it with the key seems to have restored the function.
x 5674
Just opened mine.
At the 'bottom' end, adjacent to the keyring, there is a slot.
Shove a fairly wide bladed screwdriver in and twist, the whole thing just falls apart.
May even buy a new battery now I have conquered that :D
ETA:
Interestingly enough, there are pressure pads for four buttons, wonder what the fourth is for?
x 5674
Image Image
Click on the images, then click and click again for full resolution. Should have cropped them, sorry.
Must give the board a blast of contact cleaner. Pity I reassembled it before I thought of that.
x 1942
myglaren wrote:Interestingly enough, there are pressure pads for four buttons, wonder what the fourth is for?
The buttons in my C5 remote cracked and I bought a four button remote off Ebay to repair it. I transferred the circuit board (and key) over and it all works as it should.
The extra button is marked with a door symbol with left and right arrows. The buttton which operates the dropglasses also has this symbol and operates the dropglasses as it should. The extra button does nothing.
I suspect that the original use is for the C8, or similar, with electrically operated doors perhaps?
x 5674
Yeah, I pointed the remote (board) out of the window an shorted the contact pads, all worked but the fourth one.
Could it be a boot release for the saloon?
x 1942
I don't think so, it would surely have a different picture on the button. As I said both of the auxilliary buttons have the same picture which definitely shows a door, not a tailgate or bootlid.
Query about the C8. Does the exclusive model have two electrically sliding doors? If so, I think that this will be the culprit. Possibly the Peugeot equivalent as well.
