plastic clip in Xantia
monsak
Unread post by monsak »
I took this photograph from my Xantia.
It is plastic clip that link between anti roll bar and front height corrector.
I asked my garage that is this pop off plastic clip?
He said that it is within normal position.
But in my opinoin I think it should be worn out from its socket.
Please help to tell me that Am I correct or not ?
And if I correct , Can I press it back simply or I must replace a new one.
After that,in case of simple press it back,
I must set ride height or not.
Thank you very much[img]c:\1.jpg[/img]
Dave Burns
x 3
Unread post by Dave Burns »
The plastic link should be connected at one end to the anti roll bar and the other end to the height corrector at all times.
If it is off at one end then you are correct and it is worn, or the metal ball is worn that it fits on.
You can fit another straight on, the suspension will not need adjusting.
<font color="red">MAKE SURE THE CAR IS SAFELY SUPPORTED TO PREVENT IT FROM FALLING AND TRAPPING YOU</font id="red">
Dave
