Reading this thread makes me ask:
if I am not getting any ticking from the hydraulics then can I take it that there is no need to replace?
45000miles, year 2000 Hdi90 saloon.[/b]
V6 accumulator sphere
rmunns
- x 9
lexi
- x 134
Well maybe not. They are service items however at 3yrs or 36k I think. If I am correct that sphere acts as a reservoir for emergency braking if pump stops or fails while travelling.rmunns wrote:(......no need to replace the accumulator sphere? I meant.
I`ll replace mine anyway. For the £16 plus vat that it cost I think it is worth it.
Yes Jim if valves are £300 those springs will be stretched, heat treated,ultrasonically cleaned, cryogenically blasted and even gunmetal blued in order to get a result
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Old-Guy
- x 22
For anyone who wants to understand how Citroen's hydropneumatic suspension works (in all its variants), I recommend The Citroen Technical Guide. It's quite a big PDF file, so it's worth downloading for easy reference in future.
lexi
- x 134
Well good news for me is that new Sphere cured ticking. Not bad for accsess really on this V6 sphere. Only thing was I could not get sphere removal tool in with front Valance and a pipe in way.
My trusty cold chisel (very sharp) and big engineer hammer done the trick as usual. Working on the heavy weld at middle of sphere the firm tapping at about 60deg. seems to shock it off. If you take a shaving off it`s likely the chisel is too obtuse or shallow an angle. Move around the unit if needed..........it will come off IME.
If however you have a tool and can get in then use it. It`s great when they crack loose with a bit of leverage. Like an old troublesome bottom tooth coming out:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 8137
You know Lexi, I'm not even sure if the Pleiades tool will do a V6 Accumulator due to it's location.
The only V6 accumulator I've replaced is on mine and I took the engine out to do it (amongst a few other odd jobs)
Pleased the new accumulator has done for the fast ticking
citroenxm
- Fallen Hero
- x 70
Jim,
They do - Just about and thats with a completely SHOT Pleiades removal tool!
I got mine on and changed my Acc sphere, HOWEVER, it didn't alter the regulator tick... so there must be something else wrong with the ole girl, as mentioned in another post elsewere..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lexi
- x 134
If it is the Hydractive valve on yours Paul will you not feel it with a finger on the valve as it ticks?. Or does the ticking noise come from the regulator even as a result of faulty Hydractive valve? My ticking could be heard/ felt just above the sphere on reg itself.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
- Fallen Hero
- x 70
Its a tick on the regulator unit.. never mind, shes comming to bits start of next year to sort rusty front strut feed pipes, an oil leak, air conditioning and front bumper...
Shes only used as weekend car atthe moment.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
