Hydractive spheres on an Activa
x 8441
Yes, they'll be perfect Mike :D
x 8441
There's no reason not to use standard hydractive fronts Mike. I use standard hydractive rears on the back of mine with no issues.
Unless you drive on the bleeding edge all the time, I reckon you'll find them fine. It's what I'll replace mine with when the time comes.
x 8441
Sorry for the delay Mike,
Just got a long phone call and then another straight afterward :twisted:
Right, 95666862 is the part number applicable up to RP 6778 and 5272.34 replaced it from RP 6779 onwards. Effectively no difference, just a change of part number.
I gleaned that from Laser. With a bit of effort the old and new numbers can be cross-referenced although not directly.
