Xantia towing weight
mark21td
Unread post by mark21td »
Can anyone tell me the tow weight for my Xantia as I have no hand book,
It's a 1997 1.9td vsx estate
I need to know the
Max vehicle weight
max towing weight
max gross train weight
max tow ball weight ( the max waight you can put on the tow ball)
Thanks in advance
mark
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
Citroenmad
x 110
Unread post by Citroenmad »
According to parkers, the max towing weight is 1200kg for a 1.9TD, though it doesnt have the rest of the info.
Chris.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
The kerb weight of your Xantia is 1435Kgs. It can have a payload of up to 250Kgs; and if you work to the recommended weight ratio of 85% of kerb weight, the maximum weight of your van should be around 1240Kgs. From memory of when I had a 2.1 Estate, the nose weight was 70Kgs.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1044
Unread post by wheeler »
If you go to the VIN plate on the car, The 1st weight is the gross vehicle weight & the second one is the GTW
mark21td
Thanks guys.
My caravan weighs 1080kg max with a max nose weight of 75kg so it's nicely within \:D/ and now I don't have to tow with the wifes 406.
