Hi,
Is there anybody here with an automatic 1.9td in either a xantia or a diesel? Did the ZX ever come with an auto box for the 1.9TD, I know they came with the 1.9D, but the lever looks boring and featureless, no sports mode, ewww). I know diesel engines aren't sporty, but the XUD9 isn't your usual lazy diesel engine (such as the XUD11) and is fun to drive in the ZX.
I MAY convert one myself if it's possible (which i think it is, there's a box for sale on here that came from a xantia 1.9td, so it must go with the engine), but as we all know it's not that simple really is it. I'm tempted to just buy the box just for fun and to work it all out along side the technical manual I just googlefound.
If it's mechanically possible, I may program it with aftermarket software if the engine is too simple for the box, i.e not enough sensors for the box to operate correctly.
Any advice and information would be great, I have a my eye on a Volcane already. This could be a goer, if the reception is great to the idea.
AL4 into a ZX 1.9TD
Chlorate
Not sure if the ZX TD came with an auto or not, there's certainly a chapter in the Haynes book about auto boxes in the ZX though
Good plan with the Xantia box, exactly the same engine so should be fine. Although the mounts for the Xantia may be slightly different, probably want to get a tape measure out and see if they're all in the same place before getting it.
Although the Volcanes are much more fun to drive with the manual in my opionion.
(also the black ones do look nice, mine does, they do get really really hot in the summer:P )
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
deian
citroenxm
- Fallen Hero
- x 70
The OLD Auto box was NEVER fitted to the Turbo D Engine....
It WAS ONLY fitted to the N/a D, The TD eventually got auto when the AL4 box was launched..
This combination MAY fit the ZX but im not sure if the Xantia Subframe was modified to take the AL4 box..
Then you need to plub in the ECU and the harness for the autobox..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
deian
It's because I heard it was in the Xantia that I know the engine/box should mate, but as chlorate said, does the ZX have the mounting holes in the engine bay to hold the box?citroenxm wrote: This combination MAY fit the ZX but im not sure if the Xantia Subframe was modified to take the AL4 box..
Paul
This is where I may run into problems, by the time the xantia had this box the engine was probably slightly more advanced and have developed enough sensors to run the auto-box-ecu compared to a completely mechanical bosch pump as you would expect to find in from M reg ZX.citroenxm wrote: Then you need to plumb in the ECU and the harness for the autobox...
Paul
Another concern would be the actual gear ratio's inside the box, the Xantia MAY have different ones because the box was designed with the fact that the same engine had to drive a heavier body around.... which when I come to think of it, may suit a volcane ZX better (designed sportier), especially if the final drive is smaller (i.e quicker off the mark).
So many things to think about.
- x 1240
deian
- x 1240
deian
That is a possibility too. There is one for sale in the relevant section, and lots of talk about the possibilities.
As you know, I'm a big fan of the 2.1td and it would shift the ZX nicely, but I think the ZX would prefer a sportier engine. We'll see what's possible when I get the car. There is one in the pipeline, next week hopefully.
DHallworth
- x 167
- x 8386
Fully agreed DavidDHallworth wrote:A V6 Xantia is the way forward!!
Comfort, performance, and the convenience all rolled into one!!
However, Dei's proposal of grafting an AL4 into a ZX makes great sense and prima facie should not be too difficult to achieve. A potentially very interesting project if nothing else.
Dei, forgot to say in the other threads on this topic, you'll need the flywheel and flex-plate from the donor as the torque convertor will not mount on the standard manual flywheel.
deian
