Hi,
It's the Xant Sensation '98 TD again.
Drove into work this morning and one of my colleagues comments that NONE of my brake lights were working (that'd be ND, OS and the middle boot light then...)
Looks like the brake pedal switch to me - is this a common failure on Xantia's? Can't see the part on GSF...
Thanks,
Ian.
Xantia Brake Lights
Gnerk
Xantia Brake Lights
________________________
Renault Laguna II 2.2 dCi 2002 (bought June 2012)
Nissan Micra 1.1 96P (Mrs Gnerk)
Citroen ZX 1.9D Avantage 95N (untidy but runs wells, FOR SALE JUNE 2012)
DickieG
- Monaco's youngest playboy
- x 38
- x 94
i belive the cause of brake light switch faliure is mostly down to people sitting at junctions/traffic lights with there foot on the brake pedel,
although as Richard says i have not had the fit a new switch to a XANTIA yet,
most brake light switches cant handel 42W pluss what ever the centre lamp draws through them for a prolonged period and this can melt the internal plastic components,
regards malcolm
regards malcolm
- x 8071
For us drivers of autos, that's what we must do! It does not seem to cause that much of a problem and the brake lights must, by nature, spend a lot more time on than in a manual car.citronut wrote:i belive the cause of brake light switch faliure is mostly down to people sitting at junctions/traffic lights with there foot on the brake pedel
Is yours an estate Gnerk? If so, I'd be suspecting a problem with a broken/shorted wire in the rubber concertinas that carry wires into the tailgate. It may have chafed, shorted and popped the fuse that protects this circuit. Off-hand I cannot rela which fuse it is. Alternatively, a bulb may have gone short-circuit to give the same symptoms.
DickieG
- x 38
CitroJim wrote:For us drivers of autos, that's what we must do!citronut wrote:i belive the cause of brake light switch faliure is mostly down to people sitting at junctions/traffic lights with there foot on the brake pedel
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xantidote
- x 5
Stempy
And the thing by your side has the advantage of operating on the front wheels, perfect for a front wheel drive auto.......DickieG wrote:CitroJim wrote:For us drivers of autos, that's what we must do!citronut wrote:i belive the cause of brake light switch faliure is mostly down to people sitting at junctions/traffic lights with there foot on the brake pedelEh? Blinding the person behind with the glare from your brake lights
what's that thing down by your side for? I see a need to offer a lesson in driving an auto
Lexia ponce
Lexia ponce
Citroenmad
- x 110
I nearly always sit at junctions with my foot on the brake, try not doing in an Xm auto let alone a manual!
Unless your someone who abuses the clutch and holds the bite or wants to faff on at every junction with the Xm handbrake then so be it. Id rather run the risk of blowing a bulb
Though ive always done it, brake lights are hardly dazzling in any case, well not during the day anyway.
If im going to be stopped for a few minutes or on a steep hill and not in an Xm then ill use my handbrake, but otherwise i use the foot brake.
Chris.
Chris.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Stempy
Well I guess in some cases it is advantageous to keep the brake lights on whilst stationary, such as at the back of a queue as a warning to approaching drivers, but when they pull up behind you I think it's courteous to release the foot brake, especially at night, as personally I do find modern brake lights can be really dazzling, enough in fact to hurt my eyes.
Lexia ponce
Lexia ponce
ACTIVE8
- x 6
Are you an instructor?DickieG wrote:CitroJim wrote:For us drivers of autos, that's what we must do!citronut wrote:i belive the cause of brake light switch faliure is mostly down to people sitting at junctions/traffic lights with there foot on the brake pedelEh? Blinding the person behind with the glare from your brake lights
ACTIVA
jmd
Check your bulbs, & clean the terminals. I had a similar problem a few weeks ago- no reversing lights, no brake lights, and the indicator on the dashboard showing that my rear fog lights were on, when they weren't working at all. I checked the bulbs, which were all in working order. I then cleaned the terminals, and gave them a spray of Silicone Oil & all is fine since.
DickieG
- x 38
Might beACTIVE8 wrote:Are you an instructor?DickieG wrote:CitroJim wrote:
For us drivers of autos, that's what we must do!Eh? Blinding the person behind with the glare from your brake lights
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
vince
- x 13
I agree with the concensus that it is unlikely to be your brake ligth switch. The reason is i have worked at GSF for about 3 years in total and have never been asked for a Xantia brake light switch ever. We come across all the common faults and i like Jim suspect a wiring fault somewhere on the loom. Would they be wired on a series circuit? if so then wouldnt one break / split drop the whole circuit?
- x 8071
I'm thinking a bit of education for me might be very beneficial RichardDickieG wrote:Might beACTIVE8 wrote:Are you an instructor?DickieG wrote:Eh? Blinding the person behind with the glare from your brake lights
VertVega
- x 13
unlikely to be brake light switch I keep my foot on the brake pedal when necessary, at traffic lights, uphill stops and etc. 8) Switch is operating perfectly
So, Gnerk did you check other lights of the tailgate? Reverse, fog and aux brake. I guess the answer is inside the rubber outlet (tailgate <-> body).
