Hi ,
Last night , while driving home , I found that the main beam worked and side lights , but no ! dipped headlights !
I transferred the two blown dipped headlight bulbs to the main beam ones , just to get home .
When I got home , to my amazment , the dipped headlights refused to turn off . So I unplugged the bulbs !
How bizzare !!
Anyone got any ideas ,
thanks
Terry .
Xantia Headlight Puzzle
Xantidote
- x 4
Hi Terry,
As you say, bizzare. I assume what you mean is that en route home, you found both dip bulbs blown, and that you switched both dip and main beam bulbs over, to get home. What's the situation today? Presumably no change.
Any other problem electrics or blown bulbs? Could you have had a power surge/voltage spike, say if alternator regulator playing up?
My S1 Xantia has no relays (yet) on any headlamp circuit, but not sure if read somewhere that S2 had some relays? Which model's yours? Just wondering if relay contacts could have been playing up, making and breaking repeatedly to blow the bulbs, and then finally welding together to give you the permanent "on" position. Or the fault goes back to a problem in the relay coil's operating circuit
Interested in what you find
Martin
Martin
Martin
1995 Xantia TDLX (deceased
Chevron Terry
Hi again ,
The reason for the headlights staying on ! was a fault with the alarm Relay . I have taken out the relay , now the new bulbs are ok and Iam able to turn the lights off .
Next challenge , solving the alarm problem , [ hopefully only the relay . ]
Many thanks
Terry .
Many thanks
Terry .
jgra1
- (Donor 2021)
- x 36
Xantidote
- x 4
Hi Terry - well at least you've pinpointed the problem - that's half the battle.
John - thank you for correcting me - thought I'd read somewhere about relays on S2 headlamps. Although my S1 lights are good (IMHO), checked the voltage drop on positive side which then made me think installing a relay would be beneficial. Nearly completed fitting the mods to dip beam circuit, and brief test on one headlamp showed the positive voltage drop from battery reduced by approx 1.1 volts, so a worthwhile excercise, albeit a bit fiddly
Martin
Martin
Martin
jgra1
- (Donor 2021)
- x 36
Xantidote
- x 4
