Well there is a good chance I have found a solution to one prob on the Xantia , so I might as well throw this one into the forum too !!
Rear suspension.
It has a mind of it's own. Sometimes it goes hard , like the spheres have failed , but then it can be normal ! This is an exclusive spec car so it has the suspension switch for comfort or sport (!) driving. When the suspension goes hard , if the switch is then operated momentarily ride goes back to normal 7 times out of 10 , but sometimes the switch needs to be operated for 10 or 20 seconds to get normal ride.
Also , the suspension seems to go hard during cornering , then the switch has to operated to get back to normal.
Any idea's please ?
another Xantia HDI 110 problem to be solved !
DickieG
- Monaco's youngest playboy
- x 38
It sounds as there is some fault with the rear electrovalve, a quick Lexia check may reveal all quite quickly. Bear in mind that from your description of the fault the ECU may well be in default firm mode which it will remain in until the faults are cleared with a Lexia.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8078
Further to Richard's post, once the faults are read/cleared with the Lexia, it's very likely you'll need to do the "diode mod" on the electrovalves.
Details of the mod are here. It's very straightforward.
One thing about the Hydractive ECU is that it regularly collects intermittent faults, mainly from the steering position sensor, and these can only be cleared with a Lexia. Disconnecting the battery will not do it. Any stored intermittent fault will cause the ECU to assume a default value for the sensor in question with detriment (especially on Activas) to handling and comfort.
Resetting the Hydractive ECU is regular routine service task
HDI
- x 7
Thanx guys
Now then , I need to find a local Lexia. Anyone in the Worcester or similar vicinity with a Lexia ?
Also , which type of Hydractive will my Xantia have ?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
DickieG
- x 38
HDI
- x 7
