Anyone know where the tilt switch for the boot light is located on the Xantia?
Mine has been intermittent for a while but has now quit completely. I've checked out the lamp holder and bulb and these are OK.
Dave.
Boot light switch
DaveW
Boot light switch
Xantia Forte 1.8i, 16v X reg.(09/2000) 93K, aircon
jgra1
- (Donor 2021)
- x 36
red_dwarfers
- x 58
DickieG
- Monaco's youngest playboy
- x 33
Unless I'm very much mistaken the switch mentioned above is for the alarm/(Hydractive suspension if fitted).
The light tilt switch is located behind the large black plastic panel on the inside of the tailgate, IIRC its somewhere in the middle. However I think the problem you're suffering may be being caused by a break in the wires where they enter the tailgate, pull back the rubber sleeve to examine them.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xantidote
- x 4
DickieG is right.
My 1995 1.9TD has the tilt switch behind the tailgate trim, held by 6 "plastic" screws in plastic plugs, plus 1 metal screw in the hand hold. There are also 2 metal locating lugs near the rear screen.
My tilt switch was tiny, and I prised it open to find 2 balls inside, 1 of which makes contact with a lug terminal to make the circuit. I cleaned everything up, to get mine working again, but 3-4 years on, it's playing up again. IIRC, part of problem was the balls didn't seem to be stainless, and I think there was a bit of corrosion, as one would expect on a car which was 10 years old at the time
Martin
Martin
Martin
1995 Xantia TDLX (deceased
DaveW
Thanks for the replies.
I agree that a broken wire is likely but putting the meter on the plug to the bulb holder shows 12v. on the +ve. wire but no ground connection on the -ve. wire.
I rigged a temporary earth and the light came on but failed to switch off when the boot was closed?
A bit odd that - seemed as though the -ve. wire was switched rather than the +ve. That's why I wanted to have a look at the tilt switch to see how it was wired (wish they had fitted a standard push switch as on the BX)
Any thoughts?
Dave.
Any thoughts?
Dave.
Onlinemyglaren
- x 5672
Replace with a Mercury tilt switch.
Had one for the tailgate and one for the under bonnet light (factory fitted) on the old Volvo. Never gave any trouble whatsoever.
DaveW
Martin,
Thanks, that was the info. I was hoping for _ I'll tear mine apart tomorrow.
myglaren,
Mercury is not considered to be very 'green' nowadays
so if I replace it with anything it will probably be a push to open type. Given the occasional squirt of switch cleaner, these have never caused me any problems.
Bit OT but where do you get your avatar images from? I like the one you use on DVD Reviewer forum.
Dave.
myglaren,
Dave.
Onlinemyglaren
- x 5672
The images are just off the net, some from Mylene Farmer forums.
Google Images.
Those mercury switches already exist, why not use them, much more durable than push switches.
Google Images.
jgra1
- (Donor 2021)
- x 36
Xantidote
- x 4
