Hi Colin,
I had the needle lift sensor injector on my 2.1TD fail back along. It did not affect the tacho.
It's more likely it's the TDC sensor that's not playing...
Diesel rev counter
- x 8422
colinxm
- x 1240
colinxm
Right then, I've had a poke around and the rev counter now works - whoohoo ! problem is that as soon as the engine goes even slightly above 3000rpm the rev counter dies and stays dead until the engine is switched off and restarted... It does this when driving and also when stationary, blipping the throttle also kills it
Anyone any ideas ?
Peter, mine has a three pin plug to the tdc sensor, not that I'm one to brag
Colin.P
Anyone any ideas ?
Colin.P
1995 Cit XM 2,1 TD Silver Estate
2004 Pug 307 SW
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
2004 Pug 307 SW
1998 Ford Puma
1979 Triumph TR7
- x 1240
colinxm
Thanks for that Peter but I've given up and refitted the older Bosch wiring loom again. I'm going to pull the clocks out next and compare the connections to those on a set of clocks previously fitted to a series one car, maybe then I can sort something out - perhaps the wiring to the connectors changed slightly between the two series cars.
Cheers Colin.P
Cheers Colin.P
2004 Pug 307 SW
1998 Ford Puma
1979 Triumph TR7
2004 Pug 307 SW
1998 Ford Puma
1979 Triumph TR7
colinxm
One step closer... although the pcb's are vastly different between the series one and two instrument sets the same pathways between the rev counter and the multiplugs are used, the series two even has the cutouts and connections for the turbo pressure dial in place. I thought this was only installed on the series one's.
So now I'll be digging out of the loft the "under dash" wiring loom that was fitted to the series one car to see where everything connects to the multiplug to the engine wiring harness and then compare the current loom to see where the connection is missing.
I'll even have a go at getting the turbo dial to work and retro fit it for fun
Colin.P
Colin.P
2004 Pug 307 SW
1998 Ford Puma
1979 Triumph TR7
2004 Pug 307 SW
1998 Ford Puma
1979 Triumph TR7
colinxm
- x 1240
colinxm
Hi Peter, sorry for the late reply - I've been playing some more
The error is indeed constant and the ecu is removed, in fact, with the wiring that I've added the system should be identical to that on a fully mechanical setup.
Here's what I've found:
The original (EPIC) rev counter doesn't work at all unless I replace it's own small pcb with that from an earlier model and then it reads double.
An earlier rev counter will work with both the original (EPIC) main instrument panel pcb and also that of an earlier version, again it reads double.
The only things now original from the EPIC setup are the flywheel and the TDC sensor... surely the flywheel for the EPIC setup wouldn't have two triggers for the TDC sensor mounted at 180 degrees to each other ?
Here's another thing, the ribbon cable fitting to connect the rev counter to the main instrument panel pcb are subtly different between the two models which meant some fiddling and swapping with the soldering iron to get an earlier pcb to fit... why did they have to fiddle and change EVERYTHING between the two models (rant rant)
That's it for now, Colin.P
2004 Pug 307 SW
1998 Ford Puma
1979 Triumph TR7
2004 Pug 307 SW
1998 Ford Puma
1979 Triumph TR7
- x 1240
Hi Colin
I'm stumped. The only thing you can do really is to connect an osciloscope to the output of the sensor and chek that the output frequency corresponds to the engine revs, if the frequency is double I can only think that you have a blob of something, or some damage on the flywheel, or that the flywheel is different on the EPIC. Still, it should be fun showing your 8,000 rpm diesel engine to your friends.
Xaccers
- x 188
At least it should make the smoke test during the MoT safer for the cam belt
DIY sphere tool
DIY sphere tool
colinxm
