Rear end stays down
paco
Rear end stays down
I've looked up and down the forum and can't see much about this so I'm posting a new one.
The rear end of my Xantia 1.9TDi doesn't rise, I had this problem before and had to fit a new plastic part, which has something to do with the suspension levelling, and immediately solved it.
I went under it and, like before, the plastic part had popped off and when I put it back it was fine until i drove it a few miles, when I parked it up the rear end was at its lowest again and anyone sitting in the back gets bounced around. Put it at its highest and the plastic part had popped off again.
Its only something like 80p for a new one but will this keep happening, and if so why, and can i do something about it?
Sid_the_Squid
It’s a problem with your rear height corrector, the plastic part is the linkage between the height corrector and the anti roll bar, as you have discovered without the plastic bit the height corrector cant work.
As you keep having to replace the plastic clip, I would think the height corrector has become very stiff probably with rust and dirt, you may be able to clean it up a bit on the car, enough for it to work, but for a proper job you should really take it off.
There is a guide on how to remove and clean a FRONT height corrector in the ‘handy hints and tips’ section, but I cannot find one for the rear height corrector.
Here is a good picture of the rear height corrector, you may be able to figure out how to clean by looking
http://www.flickr.com/photos/deiz92/429467953/
Always jack or axel stand a Xantia before looking underneath.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
- x 8408
citroenxm
- Fallen Hero
- x 70
It WILL NOT be the height corrector itself, but the stupid linkage that controls the anti roll bar movemnt to height controller - theres TWO moving levers on the linkage and these are MOST VERY LIKELY to have siezed SOLID, so that when the anti roll bar moves with the back end of the car, the linkage cant, so the clip has to pop off - IN WORSE case with a new clip without freeing them up, in which is BEST done off the car, the next part to break can be the anti roll bar clamp! Ive had a few snap now..Sid_the_Squid wrote: I would think the height corrector has become very stiff probably with rust and dirt,
Not sure of your mechanical abilities, but DO get the linake off, remove the height controller, by the two 11mm nuts you can see facing you when looking up, you can either LEAVE the 3 pipes connected or remove them. TAKE note to how the height corrector is linked into the levers!!
The linkage unit is attached by 3 trox head bolts, two facing the rear, and one to the side, look at the structure of the unit and you should find them.. Ive no picture for position reference for you..
The two levers should be nice and free to move..
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Sid_the_Squid
Apologies for not being specific enough, I was of course referring to the linkage, but thinking of the linkage as part of the whole height corrector assembly, I was unaware you could remove the linkage as a separate entity from the whole corrector module in suite. I stand corrected. I did not intend for my post to be misleading.
Past Citroens
'97 Xantia 1.9D sx
Past Citroens
'97 Xantia 1.9D sx
red_dwarfers
- x 58
Take a look at the this topic in the Handy Hints section. This one is for the front HC but most parts are applicable to the rear HC too.
I'll add some extra info to that topic in a bit regarding the rear HC
Kev
'19 C4 Cactus 130 Flair
- x 94
you beet me to it Paul as i was going to say similar, appart from i call the two levers turrets, and i do agree you cant free them up long term whilst in situe,
even with them off the car they take a lot of working lubeing working lubeing working lubeing working lubeing working lubeing,
to free them off properly so the two turrets are very floppy loose,
other that that Martin at Pleiades dose re/con brackets for a reasonable price
regards malcolm
regards malcolm
citroenxm
- Fallen Hero
- x 70
Sid, PLEASE be aware, I was not trying to correct you, but a LOT of height troubles are ALWAYS pointed at the height corrector, were in fact it is not at all, did the BX's ever suffer height problems, if I remember correctly, NO they didn't because they did NOT have this STUPID setup that the Xantia uses, A great shame they tried to refine the controlling of the height via the lever, but made it worse in dooing so.. The XM has the Stupid plastic links, but DO NOT use the lever setup on the height correctors... they never suffer height problems eitherSid_the_Squid wrote:Apologies for not being specific enough, I was of course referring to the linkage, but thinking of the linkage as part of the whole height corrector assembly, I was unaware you could remove the linkage as a separate entity from the whole corrector module in suite. I stand corrected. I did not intend for my post to be misleading.
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Xaccers
- x 188
Sorry to hijack, but how do the BX and XM manually set the height then?
I remember the last BX I contemplated buying had a rather vicious height lever (nearly went the same way as Malcom with it!) where the Xantia has a safer one
DIY sphere tool
DIY sphere tool
Sid_the_Squid
No worries Paul, were all here to learn and help each other, I've learned something new about the height corrector and linkages today, thus will be better able to fix issues and help others in the future.Sid, PLEASE be aware, I was not trying to correct you,
As a wise man once said "its all good".
Past Citroens
'97 Xantia 1.9D sx
Past Citroens
'97 Xantia 1.9D sx
paco
- x 94
if it works here is the BX H/C lincage
http://service.citroen.com/docpr/affich ... 3%20435110#
regards malcolm
regards malcolm
- x 94
- x 5672
- x 94
